Keyboard modification - what did I just cut through?
Let's start this with a disclaimer that what I have done is stupid and I am aware of that.
Does anyone have a picture of the traces around the pogo pin section of the keyboard case? You see I've cut through the case pretty close to the short side of that pad array nearest the camera cutout and I can see copper from the PCB. I think the VBUS trace was the only one hit but I can't be sure.
Why did I make the cut? I put an NVMe drive heatsink on the can over the SoC to help with heat, this added to the thickness of the phone so I cut through the back cover to allow it to fit and when I tried to make the same modification to the keyboard I got overzealous. Measure twice cut once!
Edit: the keyboard works but power from keyboard to pinephone doesn't seem to, that supports the damaged vbus theory
  Rii mini 4 keyboard and touchpad work over Bluetooth Peter Gamma 2 5,704 06-04-2026, 12:16 PM
Last Post: elinkser
  Pinephone (Pro) Keyboard Case for sale manubert 8 19,493 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 3,114 01-12-2026, 06:09 PM
Last Post: ragele
  keyboard case charging but not typing new2pinephone 19 27,484 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 5,531 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 23,797 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 5,365 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 3,223 07-04-2024, 05:40 AM
  Keyboard & 2.4G usb dongle for the Pinephone? Peter Gamma 2 5,063 06-29-2024, 09:36 PM
  Bluetooth keyboard with trackpad Zebulon Walton 11 23,843 06-29-2024, 04:09 AM
