Has anyone got briar-desktop running on mobian?
Has anyone got  briar-desktop running on mobian? https://code.briarproject.org/briar/briar-desktop
https://briarproject.org/how-it-works/ Briar  is a decentralized  peer to peer  messenger.   Please share your arm64 build instructions.
Update.
Brair project is now releasing an arm64 nightly-build tar. Not touch friendly. https://code.briarproject.org/briar/bria..._linux_arm
(01-17-2022, 01:49 AM)vusra Wrote: Has anyone got  briar-desktop running on mobian? https://code.briarproject.org/briar/briar-desktop
Have you tried to run it? I hope that it works. Otherwise, maybe try Jami.
I tried it (building myself, with java and flatpak), but did not succeed. I use Jami for now, the flatpak works fine.
Exclamation
Maybe I can help you. How did it fail? Was a library missing from the classpath? Did javac succeed in compiling? Which version of OpenJDK did you use?
Those build instructions should work:
https://code.briarproject.org/briar/bria...nd-running
If you just want to run it without building it, use the following command lines:
sudo apt install openjdk-17-jre wget https://code.briarproject.org/briar/briar-desktop/-/jobs/artifacts/main/raw/briar-desktop.jar?job=b_jar java -jar 'briar-desktop.jar?job=b_jar'
N.B: It doesn't work yet, libskiko is missing, it's a dependency of the Compose UI framework used in Briar Desktop:
Quote:Cannot find libskiko-linux-arm64.so.sha256, proper native dependency missing
Actually, libskiko-linux-arm64.so.sha256 and libskiko-linux-arm64.so are missing from the JAR. It's a known bug. You can find the missing files here in the latest release of skiko, look for skiko-awt-runtime-linux-arm64.jar. Adding the missing files into the nightly build is enough to make it work.
Thanks, I will try it in a few weeks. Smile
briar-desktop arm64 nightly-build tar https://code.briarproject.org/briar/bria..._linux_arm
  Mobian MMS/SMS text problem bcnaz 16 40,057 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,935 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 70,709 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 74,609 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,508 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 351,945 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 3,178 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,398 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,156 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 4,840 04-29-2025, 02:10 PM
Last Post: mdk
