PinePhone Keyboard: Space as modifier
Since about ten years, I run TouchCursor on my PC. It turns Space into a modifier:
  • Space down, i down: equivalent to
  • Space down, j down: equivalent to
  • Space down, u down: equivalent to Home
  • Space down, y down: equivalent to PgUp
  • Space down, Space up: regular space
The big advantage is that my hands don’t need to change position. I don’t use the cursor keys any more. Furthermore, with Space as modifier, I can just press it with the thumb on my right hand. Then I have my left hand to press all the other modifiers: Ctrl, Alt, Shift
Will I be able to configure the PinePhone keyboard to behave in the same way?
I think yes because any two keys can be used in combination judging from what the developer behind the firmware noted.
See: https://xnux.eu/log/#043
(10-03-2021, 05:36 AM)lot378 Wrote: I think yes because any two keys can be used in combination judging from what the developer behind the firmware noted.
Thanks! That's indeed crucial, if I want to enable TouchCursor functionality under X or Wayland. I hope this is possible, but it should. On my PC I use Windows with Linux in a VM, and TouchCursor runs on Windows.
I wonder: Will users be able to modify the firmware? Then I could hard code those key combinations.
It certainly looks like that's the intention. See https://xnux.eu/log/#044 for the later report, including links to the firmware source. Towards the end of the first set of bullet points there's discussion of the approach to flashing via i2c so users don't need to solder a USB connection, and the split between stock and user firmware.
(10-05-2021, 03:57 AM)wibble Wrote: It certainly looks like that's the intention. See https://xnux.eu/log/#044 for the later report, including links to the firmware source. Towards the end of the first set of bullet points there's discussion of the approach to flashing via i2c so users don't need to solder a USB connection, and the split between stock and user firmware.
Very cool, and thanks for the link!
I am currently running Mobian. I have found that by hitting the globe key and choosing terminal the left/right up/down keys will appear at the top of the keyboard along with ctrl and alt. So now you can move the cursor all around in your document. Hope this helps.
Thanks for the suggestion. However, I think you are referring to an on-screen keyboard, while we're discussing the hardware keyboard here.
(01-04-2022, 03:52 AM)feklee Wrote: Thanks for the suggestion. However, I think you are referring to an on-screen keyboard, while we're discussing the hardware keyboard here.
Sorry for the confusion. I have been using an external bluetooth keyboard from Amazon that has a touchpad with left/right mouse buttons. Makes navigation on the pinephone much easier.
  Rii mini 4 keyboard and touchpad work over Bluetooth Peter Gamma 2 3,393 06-04-2026, 12:16 PM
Last Post: elinkser
  Pinephone (Pro) Keyboard Case for sale manubert 8 17,008 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 1,891 01-12-2026, 06:09 PM
Last Post: ragele
  Replacement battery for PinePhone? j_s 9 8,006 06-03-2025, 04:19 PM
Last Post: j_s
  keyboard case charging but not typing new2pinephone 19 23,251 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 4,437 10-07-2024, 11:08 PM
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 19,196 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Keyboards for the PinePhone? Peter Gamma 1 4,613 07-04-2024, 10:22 PM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 4,383 07-04-2024, 07:32 AM
Heart The Pinephone keyboard offers alternative layouts Peter Gamma 0 2,494 07-04-2024, 05:40 AM
