CPU Fan Won’t Turn On in Manjaro
I have noticed that the 20mm CPU fan I bought for my RockPro64 doesn’t turn on when using Manjaro ARM. It works with Armbian though. Is there a driver/firmware/etc that has to be downloaded after install to use it ? I ask because I noticed I had to install the firmware for the wifi after the install for it to work as well. I would really prefer to use Manjaro ARM if I can get this working. I bought the 20mm fan from the Pine Store. I am using Manjaro ARM 21.12 Mate.
PinePhone BraveHeart Edition
Pinephone Convergence
PineTab
RockPro64
  [Manjaro] Fixing /etc/fstab from serial console while using lvm2 Dendrocalamus64 0 1,186 10-16-2025, 05:58 PM
Last Post: Dendrocalamus64
  prevent bluetooth from loading (manjaro, no wifi/bt card installed) flounder 0 2,916 02-17-2022, 12:10 PM
Last Post: flounder
  Manjaro ARM - Built-in ethernet was broken with kernel 5.14.1-1 (over now) Dendrocalamus64 2 5,192 09-11-2021, 08:58 PM
Last Post: t4_4t
  Headphone jack issues Manjaro Mangled 2 5,589 03-06-2021, 11:01 PM
Last Post: Mangled
Thumbs Up First Manjaro Mainline build! Luke 10 26,196 10-20-2020, 04:29 AM
Last Post: vfr400racer
  Wifi on Manjaro User 19517 0 3,361 09-14-2020, 06:53 PM
Last Post: User 19517
  No audio output with Manjaro Arm 20.04 Faradn 2 7,391 08-02-2020, 09:48 AM
Last Post: new-rockpro-user
  RockPro64 Linux Manjaro HDMI 4K mkne 12 25,157 05-03-2020, 07:23 AM
Last Post: PakoSt
