Screen and Digitzier
Two dumb questions!
1. Is the screen and digitizer a combined unit or are they separate?
2. Does (1) in the document below do anything other than protect the screen?
https://files.pine64.org/doc/datasheet/p...%201.0.pdf
I'm asking this because my Braveheart has just started playing up. I have difficulty touching some parts on the lower part of the screen, namely the area where the '6', 'y', 'h' and 'n' keys are located. The fault is intermittent.
If the digitizer is separate and/or (1) handles touch input, I was hoping to disassemble the phone and try re-seat either of them before ordering a replacement screen.
Many thanks in advance!
I'd try reseating the connector if you haven't done it already. Based on the 'Screen dying already?' thread I don't think there's a reasonable way for an end user to reassemble the screen assembly.
https://forum.pine64.org/showthread.php?tid=13636
(11-11-2021, 02:48 AM)wibble Wrote: I'd try reseating the connector if you haven't done it already. Based on the 'Screen dying already?' thread I don't think there's a reasonable way for an end user to reassemble the screen assembly.
Yep, tried that before posting. But thanks for the suggestion.
From your post, it sounds like I have to order a replacement screen.
  Screen dying already? marcih 156 310,579 06-12-2025, 06:18 AM
Last Post: mikeb
  Screen Replacement Instructions erikkugel 5 12,440 02-24-2025, 06:55 AM
Last Post: anonymous
Tongue Screen ghosting and omitting rows of pixels... bedtime 0 2,121 12-28-2023, 01:26 PM
Last Post: bedtime
  Replacement screen disconnects after back frame is screwed on robthebold 4 6,905 10-12-2023, 01:03 PM
Last Post: robthebold
  Severe screen flicker + occasional ghosting | Pinephone Beta edition legowave440 5 8,818 07-25-2022, 07:35 AM
Last Post: bedtime
  Double Image on screen Arvis 2 4,827 07-03-2022, 06:27 AM
Last Post: Avisando
  Screen has pixel-thin horizontal stripes that are black or get stuck in the past yasmi 5 9,400 03-08-2022, 12:25 PM
Last Post: jopple
  How hard to replace screen? Zebulon Walton 28 52,224 01-18-2022, 12:21 AM
Last Post: henrythemouse
  pinephone screen Uturn 2 5,360 01-14-2022, 01:15 AM
Last Post: Uturn
  Screen replacement Csanderson0313 4 7,542 01-10-2022, 09:26 PM
Last Post: Csanderson0313
