How to Make Mobian Boot to Command Line
So after a bit of experimenting, I have found a method to turn Mobian into a command line version of Debian. It may not be the best way to get this done, but it works. I am always open to other approaches. There may also be extraneous packages remaining, but I’ll leave any further tinkering to your discretion.
1. Flash the latest version of Mobian
2. Boot the phone and setup the phone, including wifi (I haven’t tested ethernet with this process, but I assume it would work also).
3. Open King’s Cross Terminal
4. Install ssh service: sudo apt install ssh (The package may be called “openssh” in some repositories and/or builds).
5. Start sshd: sudo systemctl start sshd
6. Ssh to device from another computer: ssh mobian@[ip address] (the default password should be “1234”)
7. switch to su: sudo su (the default password should be “1234”)
8. Remove gnome / phosh: apt autoremove *gnome*
9. Update the system: apt update
10. Upgrade the system: apt upgrade
11. Reboot the system: reboot now (this should reboot to command line, but it will still have the splash, and no console output).
12. Ssh in again: ssh mobian@[ip address] (the default password should be “1234”)
13. Switch to su: sudo su (the default password should be “1234”)
14. Edit boot arguments:
      a. nano /etc/default/u-boot
      b. in U_BOOT_PARAMETERS= remove the argument “splash” and add the argument “console=tty1”
      (so the argument line should looks as follows: U_BOOT_PARAMETERS="console=ttyS0,115200 consoleblank=0 loglevel=7 rw plymouth.ignore-serial-console vt.global_cursor_default=0 console=tty1")
      d. save the file
15. Write the boot arguments:
a. cd /sbin
b. u-boot-update
16. Reboot: reboot
That’s it. It should now boot to command line with console output.
I should add that if you don't want console output, don't include the boot argument "console=tty1". Be sure to run u-boot-update in /sbin after making any changes to u-boot.
You could as well have pressed CTRL + Alt + F2 on a USB keyboard though.
The other question is, unless you want to keep your PinePhone docked forever and always carry around a USB keyboard and portable battery (to power the dock), why would you do that?
母語は日本語ですが、英語も喋れます(ry
I've seen many people ask how they could find a lite image of Debian for the Pinephone. Now they have one. They can do whatever they want with it. For example, they could install a desktop with a virtual keyboard and a working phone. I've done it in Arch using KDE Plasma Desktop. So we're not as limited as you represent. That's why many of us bought this phone.
(11-01-2021, 02:19 AM)Ubermunchen Wrote: I've seen many people ask how they could find a lite image of Debian for the Pinephone. Now they have one. They can do whatever they want with it. For example, they could install a desktop with a virtual keyboard and a working phone. I've done it in Arch using KDE Plasma Desktop. So we're not as limited as you represent. That's why many of us bought this phone.
Ah, now I see why you would do that.
In that case, nice!
  Mobian MMS/SMS text problem bcnaz 16 35,833 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,114 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 62,236 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 69,828 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 2,997 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 327,867 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 2,702 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 3,646 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 4,340 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 4,111 04-29-2025, 02:10 PM
Last Post: mdk
