Screen protector.
Sadly, I was not careful when taking the top layer of the factory screen protector off of my phone. I had already put in an order for a soft case and a pine book dock to try with my main laptop. As much as I would like to order a glass protector from pine, the shipping is a bit much for just the protector. If us power supply’s were in stock I would just order both. So what I am wondering is has any one here tried a proctor for another phone and how well did it work.
Please sift through the wiki.  Other users have reported that the protector for an "iPhone 11 Pro Max / Xs Max" fits.  I seem to recall seeing this in the wiki but I cannot find it at the moment.
(02-05-2021, 09:01 PM)KC9UDX Wrote: Please sift through the wiki.  Other users have reported that the protector for an "iPhone 11 Pro Max / Xs Max" fits.  I seem to recall seeing this in the wiki but I cannot find it at the moment.
I will give that a go in the morning on my laptop. Searching does not appear to work well in the tap talk app I am thinking the one plus 6tt might also work because stacked on my 6t the 2 look close
If that works, be sure to report back here, and edit the wiki, if you can.
(02-05-2021, 11:41 PM)KC9UDX Wrote: If that works, be sure to report back here, and edit the wiki, if you can.
I have not yet tried, but the wiki says:  iPhone 11 Pro Max and the iPhone XS Max...
See https://forum.pine64.org/showthread.php?tid=8458
I have found that the Mototorola Moto Z Play also fits very well.
Screen protectors for the iPhone 11 Pro Max / Xs Max do indeed fit - I just attached one to the display.
They are pretty much the same size as the the protector the Pinephone ships with.
Plus: The phone looks much better now with its matte screen.
Thanks for this discussion, folks. In summary the users posting above have recommended the following options:
1) iPhone 11 Pro Max / Xs Max
2) Mototorola Moto Z Play
You should be able to get one of these for <$10... at least that was the case for me in Australia.
For byte-sized tech and software tips check out my Danimations Digital Media tips channel on Youtube Big Grin
Just bought a JCPal Preserver Glass iPhone 11 Pro Max/ Xs Max for $30Can. It fits nicely, and a big relief to know the screen is safer now.
Nice and clear view, responsive touchscreen, cleans more easily than the original.
  A Pinephone case that'll actually prevent the screen from cracking mil 24 37,876 11-18-2022, 02:18 PM
Last Post: mil
  Screen/Screen Protector Whitening Issue adjf873_n-s 6 11,121 03-09-2022, 02:46 AM
Last Post: adjf873_n-s
  How to Disable on-screen Keyboard? dgiffin 4 12,015 01-20-2022, 09:02 AM
Last Post: dgiffin
  PinePhone Screen Csanderson0313 7 11,665 11-14-2021, 09:06 PM
Last Post: Csanderson0313
  Pine phone Screen Protectors bcnaz 24 55,065 12-10-2020, 06:17 AM
Last Post: kqlnut
  Non-reflective (anti-glare) screen suggestions? mil 2 6,142 11-18-2020, 11:13 PM
Last Post: Raniyah
  Screen shuts off when convergence dock plugged in Lodj 1 5,176 09-10-2020, 05:29 AM
Last Post: Lodj
  Which dock for dual HDMI screen Siltaar 6 12,663 08-13-2020, 03:56 PM
