10-14-2021, 08:37 AM
Had anyone tried OpenBSD 7.0 yet? Going to try it later today hopefully.
OpenBSD 6.9 install
10-15-2021, 10:06 PM
(This post was last modified: 10-15-2021, 10:24 PM by bigtreeman.)
(05-17-2021, 02:30 AM)StickyPine Wrote: Hi, (06-19-2021, 03:05 PM)mfashby Wrote: You do need a serial console interface to usb adaptor, just get one
10-16-2021, 10:27 PM
(This post was last modified: 10-16-2021, 10:43 PM by bigtreeman.)
(05-17-2021, 02:30 AM)Today is a good day.my rk3399 based sbc now boots OpenBSD 7.0 all the way to X11 throw away 6.9 and see how the new 7.0 works for you so far not perfect, but getting closer!StickyPine Wrote: Hello,
10-29-2021, 09:40 AM
I tried openbsd7.0 with the same result as before, hanging at the same point during installer boot.
10-29-2021, 10:35 AM
You don't mention the rather large and complex config file,, 98 lines
For me,,,,,, brcmfmac43456-sdio.pine64,pinebook-pro.txt Your name may be different This is from early 2020, I avoided the update because performance was satisfactory (and others had troubles after updating)
10-29-2021, 03:35 PM
I figured out my problem. U-boot that comes with manjaro arm doesnt boot openbsd.
So: - boot linux off an SD card and wipe the eMMC card with gparted. - now the open BSD SD card boots because it uses u-boot off the SD card! I'll write up at some point everything i did, once I've managed to get it installed and wifi working etc...
10-30-2021, 02:35 PM
(10-30-2021, 02:35 PM)mfashby Wrote: Short-ish write up of where I got to. Thanks for the neat write up! It's the most easy to follow guide I've found yet. I've hit a bit of a snag though and I haven't a clue how to proceed. I've got it booting the OpenBSD install medium and I've got the serial connection working but I'm getting the following: cannot open sd0a:/etc/random.seed: No such file or directory booting sd0a:/bsd: read header failed(0). will try /bsd boot> boot> boot> boot> ls drwxr-xr-x 0,0 512 . drwxr-xr-x 0,0 512 .. ---------- 0,0 0 7.0 ---------- 0,0 0 bsd.rd ---------- 0,0 0 bsd I'm not exactly an OpenBSD expert. Is there any easy way to fix this or should I just start over? Does this indicate that I did something wrong? What I understand from the guides is that I should be booting into the installer if everything is going well. I wonder if there is any way to trigger it.
02-02-2022, 04:34 PM
(12-30-2021, 02:42 PM)koroglu Wrote:(10-30-2021, 02:35 PM)mfashby Wrote: Short-ish write up of where I got to. thanks, I'm very new to OpenBSD myself, so there's a good chance I'm wrong about some stuff. It looks like perhaps an earlier step went wrong & there's a file missing? When I wrote these instructions, it booted into the installer without seeing the message you've got there. |
| OpenBSD 7.6 | elitegamercody | 0 | 12,361 |
12-03-2024, 02:23 PM Last Post: elitegamercody |
| How to install OpenBSD on the PBP? | BenniTec | 2 | 8,873 |
10-29-2022, 02:41 PM Last Post: evantaylor |
OpenBSD 6.7 on Pinebook Pro | SKG | 27 | 71,870 |
05-07-2021, 04:03 PM Last Post: bigtreeman |
| OpenBSD on the pinebook pro | e-minguez | 5 | 16,633 |
04-27-2021, 04:06 AM Last Post: dreamer_ |
