Booted Phosh 16 Beta once and now won't boot
I downloaded the Phosh 16 Beta yesterday and played around with it for a bit then when I went to boot it up this morning it would vibrate, show the notification light turn on then go black. I left it for about 10 minutes to see if maybe it was booting up but the screen was just dim and nothing happened. I tried booting into it 4-5 times with the same result. Anyone else experiencing this?
(10-07-2021, 08:57 AM)ragreenburg Wrote: I downloaded the Phosh 16 Beta yesterday and played around with it for a bit then when I went to boot it up this morning it would vibrate, show the notification light turn on then go black. I left it for about 10 minutes to see if maybe it was booting up but the screen was just dim and nothing happened. I tried booting into it 4-5 times with the same result. Anyone else experiencing this?
sounds very similiar what i had with pre-installed k plasma.
my guess is something installed updates on a background and it got messed up, maybe package "linux-pinephone" or "linux-firmware" or else.
take a look at this https://forum.pine64.org/showthread.php?tid=14978 . i re-installed "linux-pinephone" and manage to get back (though removed it for beta phosh later).
Interesting, thanks.
I had same issue with pacman -Syu update yesterday. After extensive installs by pacmen, system was reporting that 1 files did not download properly. Did not write down name. I went to try pacman again and it wouldn't run pacman. Then it unbooted. Upon rebooting got no login after many tries.
Had to do new install with download of latest revision. After install, pacman -Syu reinstalled 400+ files. But all looks to be working now.
I think I will offload my telephone contacts before each pacman update as I never know when a reinstall might be needed.
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 10 20,074 10-04-2024, 12:01 AM
Last Post: spazz
  Boot fails ionmich 6 8,103 11-02-2023, 05:14 AM
Last Post: Uturn
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 3,783 04-25-2023, 09:49 AM
Last Post: jakfish
  Backup and Home Screen Tinkering on Phosh jakfish 0 2,626 02-24-2023, 12:56 PM
Last Post: jakfish
  Manjaro plasma-mobile Beta 13 Uturn 13 17,329 01-25-2023, 04:15 PM
  MMS workaround for users with separate APN (works atleast on Manjaro Phosh) alaraajavamma 0 3,004 10-10-2022, 12:53 PM
Last Post: alaraajavamma
Question Running AnBox on Manjaro ARM w/ Phosh? danimations 2 5,905 09-05-2022, 03:42 PM
Last Post: nroth
Question Help installing Snaps on Pinephone running Manjaro ARM w/ Phosh danimations 2 4,800 04-07-2022, 06:02 AM
Last Post: danimations
  Manjaro Plasma Beta and Cellular Data Service Fred Zyphal 7 12,420 03-17-2022, 05:50 PM
Last Post: Fred Zyphal
  Manjaro Phosh Issues Csanderson0313 7 12,272 03-05-2022, 08:23 AM
Last Post: Csanderson0313
