Pinephone fan case w. StructureCore cable option
I just would like to mention that I made a pinephone case printable in 5 colors, containing the Tux logo and Pine64 logo (sort of fan item I would say - don't expect it to be a "protective" case). It is available with or without a protector for an OTG cable and a cable holder as well. I put the item on thingieverse in case anyone else would like one: https://www.thingiverse.com/thing:4933237
I also wrote a small piece of scanning software for StructureCore on the pinephone (it only scans and records, some preview and settings, nothing fancy). In case anyone is interested the source code I would love to share it. BTW You can find a protective StructureCore shell here: https://www.thingiverse.com/thing:4933248
Summary for StructureCore on pinephone: there is nowhere near full scanner performance, I can scan around 5fps using the pinephone. It's great fun anyway! I just compiled (on manjaro) and it worked (except their windowing; however, gtk3 works finewith the library on manjaro).
(08-15-2021, 12:59 PM)frimmel Wrote: I just would like to mention that I made a pinephone case printable in 5 colors, containing the Tux logo and Pine64 logo (sort of fan item I would say - don't expect it to be a "protective" case). It is available with or without a protector for an OTG cable and a cable holder as well. I put the item on thingieverse in case anyone else would like one: https://www.thingiverse.com/thing:4933237
Can you do one with exterior antenna jacks for lte,gps,and wifi and posibbly an extra battery of the same type that comes with the phone?
I guess it should be possible, if I have the specs for it (do you have them?). An extra battery pack would indeed be nice, how did you plan to connect it to the phone?
The LTE uses a cable to go between the main and USB-C boards, so that part would be relatively easy. The GPS and WiFi will be trickier as they use sprung contacts to the printed antennae on the inner frame. You might be able to make a flexi pcb to stick to the inside of the inner frame at the contact points and lead them to a connector I suppose, or go the invasive route by removing the sprung contacts and soldering a coax pigtail in their place.
I got my PinePhone PRO (explorer) today and can conclude the following:
a/ The fan case I made for the Pinephone suits the PRO just fine.
b/ The (occipital) StructrureCore software compiles without hazzle (need gcc, make, cmake and pkgconf, that's all, then just build it).
c/ (for my implementation), the Structrure Core can stream around 9fps (highest quality) as compared to around 5 for the pinephone. Even though this difference might not seem too big, it makes a difference when actually scanning.
  Pinephone (Pro) Keyboard Case for sale manubert 8 18,764 05-15-2026, 11:36 AM
Last Post: oliveira11670
  NEW pinephone keyboard case and LoRa backplate for sale ragele 0 2,746 01-12-2026, 06:09 PM
Last Post: ragele
  Replacement battery for PinePhone? j_s 9 10,151 06-03-2025, 04:19 PM
Last Post: j_s
  keyboard case charging but not typing new2pinephone 19 26,201 02-14-2025, 04:09 PM
Last Post: zltpxqhp69o2
  Searching for a PinePhone Keyboard Case RubiksCube 1 5,278 10-07-2024, 11:08 PM
  Troubleshooting Pinedio LoRa Add-on Case nickp 2 4,305 09-29-2024, 09:17 PM
Last Post: lavabrilliant
  Getting started with fingerprint scanner case lolgzs 1 5,423 09-08-2024, 04:21 AM
Last Post: mfashby
  So which keyboard you suggest for the Pinephone? Peter Gamma 21 22,433 07-19-2024, 08:05 AM
Last Post: Peter Gamma
  Keyboards for the PinePhone? Peter Gamma 1 5,282 07-04-2024, 10:22 PM
  Bring the Pinephone keyboard back, it is worth it! Peter Gamma 1 5,129 07-04-2024, 07:32 AM
