PmOS Phosh: set compose and change layout
How can I :
set compose to Pause
and
change layout to R-Alt
in PmOS Phosh?
One question: what do you mean?
母語は日本語ですが、英語も喋れます(ry
good question. in X11, you can use the Plasma settings menu or 'setxkboption' to assign a key to serve as the 'compose' key. This helps you type uncommon characters. I have the OS/Pine key set to 'compose' so I can type em dashes — and the degree symbol °. There's a similar way to set which key or combo switches keyboard layouts. I often switch between Dvorak and Russian.
I have a custom keyboard set up with QMK to work with the keys set as above. It works perfectly on my Plasma PBP, and it would be great if it would work on my phone with Pinephone with Phosh
In that case, I'm not sure.
I always make such symbols using Fcitx.
So I type for example "30do", hit space to get through the list until I get to "30℃", or I type "marukyuu" to get ⑨, or "sikaku" for ■ and □, or "rosiamoji" for the entire list of Russian characters to choose from, or "ahya" for (゚∀゚), or "nippon" for ??, and so on.
I honestly didn't even know there was some key for that to do the same thing.
  pmos firewall fxkl47BF 0 710 06-20-2026, 08:40 AM
Last Post: fxkl47BF
  box86 Actually Works Well on Manjaro Phosh/xfce jakfish 9 11,328 06-30-2024, 12:26 AM
Last Post: Peter Gamma
  Phosh - Tweaks and Customizing mikehenson 0 5,797 01-07-2023, 01:35 PM
Last Post: mikehenson
  No sms receival on Arch Phosh Pinephone pineuser0 2 4,425 10-09-2022, 08:55 AM
Last Post: treebeard
  Hey Phosh Folks !! Chief 4 6,031 09-06-2022, 12:55 AM
Last Post: Eugo
  Manjaro phosh no screen rotation sandspur 1 3,842 06-23-2022, 01:02 AM
Last Post: rapp
  Phosh - Squeekboard Layout mikehenson 0 3,217 01-21-2022, 10:53 PM
  Mobian updates for phosh steves 2 5,945 01-17-2022, 02:18 AM
Last Post: bcnaz
  reduce Phosh bottom bar to corner icon? stozi 0 2,618 08-01-2021, 02:24 PM
Last Post: stozi
  Manjaro Phosh Beta 10...how to get button labels on Angelfish? INSTRUCTIONS WITHIN patrio 4 10,616 06-11-2021, 07:10 AM
Last Post: patrio
