How to connect with wifi ?
#21
(05-22-2016, 01:49 PM)Hi,Thanks for your reply. Yes I am using the official Wifi board. Also I am running the Debian Mate, how can I configure it? Without any modification, I can connect to the router, but cannot get online. Then I try to change the wpa_supplicant.conf and interfaces, but still fail.  jl_678 Wrote: Hi,
To be clear you are working with the official WiFi board, correct?
Are you running a desktop like Mate? That is the easiest way to to configure it.
If not then did you follow my instructions exactly? Where does it show unmanaged?
Sent from my XT1254 using Tapatalk
Can you provide the output of sudo ifconfig?
Here is the ifconfig:
debian@pine64pro:~$ sudo ifconfig [sudo] password for debian: eth0      Link encap:Ethernet  HWaddr 36:c9:e3:f1:b8:05            inet addr:192.168.0.112  Bcast:192.168.0.255  Mask:255.255.255.0          inet6 addr: fe80::34c9:e3ff:fef1:b805/64 Scope:Link          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1          RX packets:2064 errors:0 dropped:0 overruns:0 frame:0          TX packets:960 errors:0 dropped:0 overruns:0 carrier:0          collisions:0 txqueuelen:1000          RX bytes:2675638 (2.5 MiB)  TX bytes:87294 (85.2 KiB)          Interrupt:114 lo        Link encap:Local Loopback            inet addr:127.0.0.1  Mask:255.0.0.0          inet6 addr: ::1/128 Scope:Host          UP LOOPBACK RUNNING  MTU:65536  Metric:1          RX packets:4 errors:0 dropped:0 overruns:0 frame:0          TX packets:4 errors:0 dropped:0 overruns:0 carrier:0          collisions:0 txqueuelen:0          RX bytes:240 (240.0 B)  TX bytes:240 (240.0 B) rename4   Link encap:Ethernet  HWaddr 34:c3:d2:6d:4b:68            inet addr:192.168.1.111  Bcast:192.168.1.255  Mask:255.255.255.0          inet6 addr: fe80::36c3:d2ff:fe6d:4b68/64 Scope:Link          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1          RX packets:404 errors:0 dropped:0 overruns:0 frame:0          TX packets:105 errors:0 dropped:1 overruns:0 carrier:0          collisions:0 txqueuelen:1000          RX bytes:88215 (86.1 KiB)  TX bytes:16487 (16.1 KiB)
Here is the iwconfig:
debian@pine64pro:~$ sudo iwconfig eth0      no wireless extensions. rename4   IEEE 802.11bgn  ESSID:"Propagation-Guest-2.4GHz"  Nickname:"<WIFI@REALTEK>"          Mode:Managed  Frequency:2.437 GHz  Access Point: F8:1A:67:2E:F7:D9            Bit Rate:150 Mb/s   Sensitivity:0/0            Retry:off   RTS thr:off   Fragment thr:off          Encryption key:****-****-****-****-****-****-****-****   Security mode:open          Power Management:off          Link Quality=99/100  Signal level=-68 dBm  Noise level=0 dBm          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0          Tx excessive retries:0  Invalid misc:0   Missed beacon:0 sit0      no wireless extensions. lo        no wireless extensions. wlan1     unassociated  Nickname:"<WIFI@REALTEK>"          Mode:Managed  Frequency=2.412 GHz  Access Point: Not-Associated            Sensitivity:0/0            Retry:off   RTS thr:off   Fragment thr:off          Encryption key:off          Power Management:off          Link Quality=0/100  Signal level=0 dBm  Noise level=0 dBm          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
and here is my interfaces:
# interfaces(5) file used by ifup(8) and ifdown(8) # Include files from /etc/network/interfaces.d: #source-directory /etc/network/interfaces.d # Primary Ethernet auto eth0 iface eth0 inet dhcp # Disable Secondary Wireless Lan (8723bs Has Two Interfaces) iface wlan1 inet manual #wlan0 #auto wlan0 #iface wlan0 inet dhcp #wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf #iface pine64 inet dhcp #rename4/wlan0 auto rename4 iface rename4 inet dhcp wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf iface pine64 inet dhcp
Also my wpa_supplicant.conf:
network={ ssid="Propagation-Guest-2.4GHz" psk="1234567890" proto=WPA RSN key_mgmt=WPA-PSK pairwise=CCMP TKIP group=CCMP auth_alg=OPEN id_str="pine64" }
Okay so I am comparing your files and mine and all are pretty much the same.  The one difference is your wpa_supplicant.conf.  The differences do not seem significant though.  Perhaps try matching mine exactly?  Here is mine:
network={       ssid="MyNetworkName"       psk="MyNetworkPasscode"       proto=RSN       key_mgmt=WPA-PSK       pairwise=CCMP       group=CCMP       auth_alg=OPEN       priority=9       id_str="pine64" }
There is a simple fix for wlan0 showing up as rename4. Just delete, or rather move /etc/udev/rules.d/70-persistent-net.rules to somewhere else. That will trigger /lib/udev/write_net_rules to execute again. When I did that I found it only made one entry for wlan0, if left wlan1 and eth0 alone. After that systemd-udevd should just use wlan0.
I would also suggest adding
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev update_config=1
to the top of your /etc/wpa_supplicant/wpa_supplicant.conf. After that and a quick reboot everything worked as expected. It seems systemd starts wpa_supplicant and that can cause some strangeness. If you are getting wpa_supplicant errors check /var/log/deamon.log
(05-25-2016, 05:55 PM)I followed your idea, now it back to wlan0. But still cannot get the web browser online.  JamesHarris Wrote: There is a simple fix for wlan0 showing up as rename4. Just delete, or rather move /etc/udev/rules.d/70-persistent-net.rules to somewhere else. That will trigger /lib/udev/write_net_rules to execute again. When I did that I found it only made one entry for wlan0, if left wlan1 and eth0 alone. After that systemd-udevd should just use wlan0.
I switched to Debian XFCE image, and now the WiFi is working
(05-25-2016, 05:55 PM)JamesHarris Wrote: There is a simple fix for wlan0 showing up as rename4. Just delete, or rather move /etc/udev/rules.d/70-persistent-net.rules to somewhere else. That will trigger /lib/udev/write_net_rules to execute again. When I did that I found it only made one entry for wlan0, if left wlan1 and eth0 alone. After that systemd-udevd should just use wlan0.
The rename thing has been annoying me and so I decided to do this. It worked perfectly and now my WiFi connection is listed as wlan0 as expected.
Thank you!
  Q4OS WiFi Dongle not working cheezmeister 3 8,348 04-07-2017, 08:01 AM
Last Post: iccoldbeer
  Wifi connect through terminal? cheezmeister 0 3,567 04-02-2017, 09:44 AM
Last Post: cheezmeister
  Bringing up wifi dongle m16bishop 2 7,217 07-04-2016, 03:24 PM
Last Post: m16bishop
