How to connect with wifi ?
I booted the pine64 with newer version of debian lenny raposo. But I got the same behaviour, when I tried to open a website. It tries to load the page but could not open. Then I typed
sudo ifdown eth0
and weasel opened the webpage. I checked the interface and the
autodown eth0
line was already commented out.
ok can you give me the results of
1) uname -a
2) sudo ifconfig
3) sudo iwconfig
thx
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
debian@pine64pro:~$ sudo uname -a Linux pine64pro 3.10.101-0-pine64-longsleep #39 SMP PREEMPT Sat May 7 12:39:25 CEST 2016 aarch64 GNU/Linux
debian@pine64pro:~$ sudo ifconfig lo        Link encap:Local Loopback             inet addr:127.0.0.1  Mask:255.0.0.0           inet6 addr: ::1/128 Scope:Host           UP LOOPBACK RUNNING  MTU:65536  Metric:1           RX packets:658 errors:0 dropped:0 overruns:0 frame:0           TX packets:658 errors:0 dropped:0 overruns:0 carrier:0           collisions:0 txqueuelen:0           RX bytes:58141 (56.7 KiB)  TX bytes:58141 (56.7 KiB) rename4   Link encap:Ethernet  HWaddr 34:c3:d2:7b:4e:b7             inet addr:192.168.0.18  Bcast:192.168.0.255  Mask:255.255.255.0           inet6 addr: fe80::36c3:d2ff:fe7b:4eb7/64 Scope:Link           UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1           RX packets:2830 errors:0 dropped:19 overruns:0 frame:0           TX packets:1887 errors:0 dropped:0 overruns:0 carrier:0           collisions:0 txqueuelen:1000           RX bytes:3364780 (3.2 MiB)  TX bytes:249434 (243.5 KiB)
debian@pine64pro:~$ sudo iwconfig eth0      no wireless extensions. rename4   IEEE 802.11bgn  ESSID:"Network Name"  Nickname:"<WIFI@REALTEK>"           Mode:Managed  Frequency:2.412 GHz  Access Point: FC:4A:E9:14:BC:3F              Bit Rate:72.2 Mb/s   Sensitivity:0/0             Retry:off   RTS thr:off   Fragment thr:off           Encryption key:****-****-****-****-****-****-****-****   Security mode:open           Power Management:off           Link Quality=100/100  Signal level=-58 dBm  Noise level=0 dBm           Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0           Tx excessive retries:0  Invalid misc:0   Missed beacon:0 sit0      no wireless extensions. lo        no wireless extensions. wlan1     unassociated  Nickname:"<WIFI@REALTEK>"           Mode:Managed  Frequency=2.412 GHz  Access Point: Not-Associated              Sensitivity:0/0             Retry:off   RTS thr:off   Fragment thr:off           Encryption key:off           Power Management:off           Link Quality=0/100  Signal level=0 dBm  Noise level=0 dBm           Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0           Tx excessive retries:0  Invalid misc:0   Missed beacon:0
So you have the latest kernel
and wireless is there
It looks like your adapter is called rename4
give me the results of cat /etc/network/interfaces
Cheers Big Grin
here it is:
debian@pine64pro:~$ cat /etc/network/interfaces # interfaces(5) file used by ifup(8) and ifdown(8) # Include files from /etc/network/interfaces.d: #source-directory /etc/network/interfaces.d # Primary Ethernet auto eth0 iface eth0 inet dhcp # Disable Secondary Wireless Lan (8723bs Has Two Interfaces) iface wlan1 inet manual
I am seeing the same issue on a fresh install of your debian build.  I previously installed Longsleep's Ubuntu build and the wifi worked perfectly and so I think that it has something to do with this image.
We appear to be getting an IP from DHCP.  The name of the interface is "rename4" which also seems odd to me.  Below is the output from uname -a, ifconfig, iwconfig, interfaces and for the heck of it, wpa-supplicant.conf.  Note that I modified both interfaces and wpa-supplicant.conf using settings that worked in the Ubuntu build.
uname -a
ifconfig
eth0      Link encap:Ethernet  HWaddr 36:c9:e3:f1:b8:05           inet6 addr: fe80::34c9:e3ff:fef1:b805/64 Scope:Link           UP BROADCAST MULTICAST  MTU:1500  Metric:1           RX packets:0 errors:0 dropped:0 overruns:0 frame:0           TX packets:5 errors:0 dropped:0 overruns:0 carrier:0           collisions:0 txqueuelen:1000           RX bytes:0 (0.0 B)  TX bytes:670 (670.0 B)           Interrupt:114 eth0:avahi Link encap:Ethernet  HWaddr 36:c9:e3:f1:b8:05           inet addr:169.254.9.92  Bcast:169.254.255.255  Mask:255.255.0.0           UP BROADCAST MULTICAST  MTU:1500  Metric:1           Interrupt:114 lo        Link encap:Local Loopback           inet addr:127.0.0.1  Mask:255.0.0.0           inet6 addr: ::1/128 Scope:Host           UP LOOPBACK RUNNING  MTU:65536  Metric:1           RX packets:243 errors:0 dropped:0 overruns:0 frame:0           TX packets:243 errors:0 dropped:0 overruns:0 carrier:0           collisions:0 txqueuelen:0           RX bytes:21008 (20.5 KiB)  TX bytes:21008 (20.5 KiB) rename4   Link encap:Ethernet  HWaddr 34:c3:d2:96:84:85           inet addr:192.168.0.134  Bcast:192.168.0.255  Mask:255.255.255.0           inet6 addr: fe80::36c3:d2ff:fe96:8485/64 Scope:Link           UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1           RX packets:695 errors:0 dropped:0 overruns:0 frame:0           TX packets:313 errors:0 dropped:0 overruns:0 carrier:0           collisions:0 txqueuelen:1000           RX bytes:127884 (124.8 KiB)  TX bytes:56683 (55.3 KiB)
iwconfig
eth0      no wireless extensions. rename4   IEEE 802.11bgn  ESSID:"MyNetworkName"  Nickname:"<WIFI@REALTEK>"           Mode:Managed  Frequency:2.462 GHz  Access Point: C4:E9:84:E0:B9:42           Bit Rate:150 Mb/s   Sensitivity:0/0           Retry:off   RTS thr:off   Fragment thr:off           Encryption key:****-****-****-****-****-****-****-****   Security mode:open           Power Management:off           Link Quality=98/100  Signal level=-45 dBm  Noise level=0 dBm           Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0           Tx excessive retries:0  Invalid misc:0   Missed beacon:0 sit0      no wireless extensions. lo        no wireless extensions. wlan1     unassociated  Nickname:"<WIFI@REALTEK>"           Mode:Managed  Frequency=2.412 GHz  Access Point: Not-Associated           Sensitivity:0/0           Retry:off   RTS thr:off   Fragment thr:off           Encryption key:off           Power Management:off           Link Quality=0/100  Signal level=0 dBm  Noise level=0 dBm           Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0           Tx excessive retries:0  Invalid misc:0   Missed beacon:0
interfaces
# interfaces(5) file used by ifup(8) and ifdown(8) # Include files from /etc/network/interfaces.d: #source-directory /etc/network/interfaces.d # Primary Ethernet auto eth0 iface eth0 inet dhcp #wlan0 auto wlan0 iface wlan0 inet dhcp wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf iface pine64 inet dhcp # Disable Secondary Wireless Lan (8723bs Has Two Interfaces) iface wlan1 inet manual
wpa_supplicant.conf
network={        ssid="MyNetworkName"        psk="MyNetworkKey"        proto=RSN        key_mgmt=WPA-PSK        pairwise=CCMP        group=CCMP        auth_alg=OPEN        priority=9        id_str="pine64" }
I keep exploring this and found something interesting. Using "ping -I" seems to work over rename4.  However if I ping the same domain with "ping" it fails.  This feels like some kind of routing issue.
debian@pine64pro:~$ ping -I "rename4" abc.com PING abc.com (199.181.132.250) from 192.168.0.134 rename4: 56(84) bytes of data. 64 bytes from play.toontown.com (199.181.132.250): icmp_seq=1 ttl=239 time=95.9 ms 64 bytes from play.toontown.com (199.181.132.250): icmp_seq=2 ttl=239 time=91.2 ms debian@pine64pro:~$ ping abc.com PING abc.com (199.181.132.250) 56(84) bytes of data. From pine64pro.local (169.254.9.92) icmp_seq=1 Destination Host Unreachable From pine64pro.local (169.254.9.92) icmp_seq=2 Destination Host Unreachable From pine64pro.local (169.254.9.92) icmp_seq=3 Destination Host Unreachable
I found a solution to this that works for me.  It requires a couple of file modifications.  Here you go.
/etc/network/interfaces.d - Add the following:
#rename4/wlan0 auto rename4 iface rename4 inet dhcp wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf iface pine64 inet dhcp
/etc/wpa_supplicant - create the file (if it is not already there) and put in the following:
network={        ssid="YourNetworkName"        psk="YourNetworkKey"        proto=RSN        key_mgmt=WPA-PSK        pairwise=CCMP        group=CCMP        auth_alg=OPEN        priority=9        id_str="pine64" }
Then you need to restart the the rename4 interface or reboot.  To restart to the following.  (If you are missing ifconfig, you can get it with apt-get install net-tools):
sudo ifconfig rename4 down sudo ifconfig rename4 up
This solution worked for me....
(05-16-2016, 02:12 PM)I followed your modification, but still cannot get online. It just shows rename4 - device not managed. Any idea I can fix this issue?Thanks jl_678 Wrote: I found a solution to this that works for me.  It requires a couple of file modifications.  Here you go.
To be clear you are working with the official WiFi board, correct?
Are you running a desktop like Mate? That is the easiest way to to configure it.
If not then did you follow my instructions exactly? Where does it show unmanaged?
Sent from my XT1254 using Tapatalk
  Q4OS WiFi Dongle not working cheezmeister 3 8,349 04-07-2017, 08:01 AM
Last Post: iccoldbeer
  Wifi connect through terminal? cheezmeister 0 3,568 04-02-2017, 09:44 AM
Last Post: cheezmeister
  Bringing up wifi dongle m16bishop 2 7,217 07-04-2016, 03:24 PM
Last Post: m16bishop
