4pin Connector for dual SATA
Hi
I want to build a cable to power the RockPro64 from "dual SATA drives". This connector is direct connected to the usual DC-power.
Does any one knows the name of the connector or have a link?
The connector info and location so far:
4 pin connector
Diamgram23
Con15
DC out for SATA disk cable (direct connect from DC-IN)
https://wiki.pine64.org/index.php/ROCKPro64
/Mats
(05-07-2020, 02:32 AM)m.ekstrom Wrote: Hi
4 pin connector
Diamgram23
Con15
/Mats
4 pins XH-type connector
I'm wondering if the CON15 could also be used as the DC IN, of course the normal Jack should not be connected then.
Does anyone has any hint on this?
Martin
(05-14-2020, 02:33 AM)mabs Wrote: Hi,
Martin
You can use it as a DC in.  That’s what I’m doing as it was a better fit for the enclosure I’m building.
Many thanks, will change that on my systems also then.
Kind Regards
Martin
  (real) Mainline U-boot finally works on SPI, boots SATA, throw away your SD cards NOW aleksei 0 371 06-21-2025, 06:21 AM
Last Post: aleksei
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 163,842 09-25-2023, 12:46 AM
Last Post: ChriChri
  Sata HD stopped booting db579 2 3,406 03-11-2022, 03:34 PM
Last Post: db579
  Dual Monitor Setup cmodernel004 3 7,997 03-08-2021, 06:02 PM
Last Post: Mangled
  Never ever mix up CPU board connector with 8-pin PCIE connector LMM 0 2,353 02-11-2021, 10:18 AM
Last Post: LMM
  fan continously runs on kernel 5.8 but I need to use 5. kernel for PCIe sata card GreyLinux 4 7,484 10-20-2020, 10:52 AM
Last Post: GreyLinux
  RockPro64 SSD Expansion Board/SATA Shield as0zial 5 9,677 10-18-2020, 08:05 PM
Last Post: revoman
  Defective? PCI-E -> SATA card no work good unregisteredidiot 11 17,625 02-19-2020, 09:08 AM
Last Post: fysa
  DSI connector is 30 pins NOT 32 ( be aware) AmroIb 3 6,273 05-25-2019, 06:15 AM
Last Post: dukla2000
  Usb3 to sata and USB C to sata / openmedia RockPro64Newbie 1 3,430 01-19-2019, 04:45 PM
Last Post: oreggin
