what file controls the repositories
I have KDE Plasma desktop installed. I think the testing repos bork my system, I would like to remove them. What file contains this?
I looked around in /etc/ for repo lists, but didnt find one.
As a temp fix, i blocked the testing repo on my network. its a dirty hack, but seems to work. I'd like to know how to do it proper.
What OS are you using? Plasma is currently available at least in Postmarket OS and KDE Neon. And it is probably possible to get it running with Debian as well.
(04-26-2020, 10:15 AM)Boern Wrote: What OS are you using? Plasma is currently available at least in Postmarket OS and KDE Neon. And it is probably possible to get it running with Debian as well.
There exists https://jbbgameich.github.io/debian-pm/install/
I've not tested it myself.
If your distribution uses apt you should have a look at /etc/apt/sources.list or the sources.list.d directory.
Sidenote: If something borked your system you could always try reflashing.
PostmarketOS has /etc/apk/repositories
  What File Manager Options Are There For The Pinephone? pinephoneuser22 7 2,523 10-18-2023, 08:37 AM
Last Post: luppivega
  Flat-file database script for pinephone terminal cabbie001 0 1,238 11-21-2021, 06:17 PM
Last Post: cabbie001
  Howto: Create Encrypted Volume Inside Video File (Zulucrypt) RTP 0 1,666 05-22-2021, 05:35 PM
Last Post: RTP
  Mobian App Menu File Location? reGisterGan578 2 3,179 02-23-2021, 11:07 AM
Last Post: reGisterGan578
  Minetest with mobile controls Gamey 1 2,513 02-04-2021, 02:16 AM
Last Post: paju1986
