Flat-file database script for pinephone terminal
For anyone interested, the simple flat-file database -- fields.awk -- does run perfectly well on the pinephone terminal, whether it's running Manjaro or Mobian. (Have not tested others) The code can be found here:
SoureForgeLink
Make the file (fields.awk) executable, move it to /usr/local/bin, and change the name to simply "fields" or a short name of your choosing.
Run it once from the command line and it will auto create its own folders .fields/db-archive. You should see a startup display such as this:
FIELDS.AWK:
Flat-file Database Program for Linux systems
® READ from:
(W) WRITE to:
(E) EDIT selected:
(S) SELECT a database
(T) TALLY a column in:
(N) NEW database
(F) Saved-FILES (in .fields/SEARCHES)
(X) Encrypt/Decrypt (files in .fields/db-archive)
(Q) Quit
Typing "N" or "n" will allow you to create one new database file as you're prompted to enter the number of desired fields, and a name for each field.
Enjoy.
  Using Signal on PinePhone in mid-2023? dante404 47 14,146 05-03-2024, 02:19 AM
Last Post: dragonhospital
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 38 25,627 04-23-2024, 10:29 AM
Last Post: donchurch
  PinePhone app development WhiteHexagon 15 4,213 04-23-2024, 05:19 AM
Last Post: Jonnyc
Wink PINEPHONE not booting Touchwood 2 552 02-23-2024, 07:27 AM
Last Post: Touchwood
  Slack on PinePhone Adam Seline 5 5,519 12-20-2023, 07:20 AM
Last Post: nickolas
  Struggle to install LibreOffice on the PinePhone Peter Gamma 48 24,943 11-24-2023, 07:02 AM
Last Post: Peter Gamma
  Which word processor to choose for the Pinephone? Peter Gamma 8 2,169 11-23-2023, 01:06 AM
  openSUSE for Pinephone Alefnode 75 103,249 11-17-2023, 08:37 AM
Last Post: Uturn
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 1,063 11-04-2023, 07:23 PM
  Abiword as a office mobile word processor for the Pinephone? Peter Gamma 11 2,475 10-24-2023, 08:57 AM
