Android TV 9 - sleeping mode and backup
Hi everyone,
As a real noobie I have install android tv on my rock64 card board; I'm using it principaly to run KODI (might not be the smartest way to do it but that was my way).
It works almost perfectly but I am facing some problems:
- the board turns off when turning the TV in sleeping mode: is there a way to deactivate on android tv specifically the ANYNET+? what is weird is that the board turn off and on with the official IR remote that work, but I can't awake the board once off by the tv remote.
Any solutions?
- android tv is running very well but it isn't constant. Sometimes it is slow (more than 3 minutes) to fast to start and in that case it is running then slow ; I'm suspecting my RJ45 plug/connection (it connected to the network through a cable)
did someone have had any problem with the onboard plug?
- Backup(ing) my PC computer: what would be the simpliest way (using android tv) to back my PC on hard disk plugged to the ROCK64?
- last but not least: chromecast is integrated to android tv, is there a way to cast from my phone to the ROCK64 if the connection is done via a RJ45 wire?
I have checked on the different thread and I haven't found the answer, but I might haven't look well
thank for reading this message,
Ludovic
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,279 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,036 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,560 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 168,633 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,026 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,507 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 6,024 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,582 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,736 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,826 09-09-2020, 08:44 AM
Last Post: BowerR64
