More useful terminal key layout for phosh's squeekboard
#21
(01-15-2022, 02:42 AM)arcanemachine Wrote: The dot in the `.local` folder means it's a hidden folder. The folders `squeekboard` and `keyboards` may not exists, so you'll need to use `mkdir` to make them.
I might add:
mkdir -p ~/.local/share/squeekboard/keyboards/
That way you can create both directories in 1 go, and if they already exist, nothing will happen.
And if only "squeekboard" exists but not "keyboards", then only "keyboards" will be created.
母語は日本語ですが、英語も喋れます(ry
Thank you for the clarification. I will give it a try.
Photo Mobian with X11 without Wayland and Phosh. Manieck71 0 957 09-09-2023, 07:35 AM
Last Post: Manieck71
  How to disable lock screen in Phosh? lat 14 14,266 03-31-2023, 04:17 AM
Last Post: Eugo
  Article: NuttX RTOS for PinePhone: LVGL Terminal for NSH Shell lupyuen 0 1,294 02-01-2023, 10:11 PM
Last Post: lupyuen
  Fedora + Phosh for PinePhone njha 74 131,097 12-12-2022, 10:19 PM
Last Post: wcdeich4@hotmail.com
  Enable 'upcoming-events' on Mobian/Phosh Korac 3 2,238 09-14-2022, 01:19 AM
Last Post: dukla2000
  Advise: ENABLE animations before updating phosh! Otherwise freezes and crashes! dante404 5 3,248 08-18-2022, 02:03 PM
Last Post: dante404
  Phosh message notifications issue itstoughtofocus 2 2,703 08-15-2022, 06:39 AM
Last Post: nemsys
  Building an image with phosh liara 1 1,798 02-01-2022, 08:26 AM
Last Post: kqlnut
  Flat-file database script for pinephone terminal cabbie001 0 1,224 11-21-2021, 06:17 PM
Last Post: cabbie001
  Phosh: Idles to Lockscreen Without Powering Off Display Merc 1 1,951 11-01-2021, 09:00 AM
Last Post: e1337
