Force on PinePhone
I left my phone without the battery in for a few days, and I cannot get it to turn on now. I have attempted to leave it plugged in to charge for over 3 hours, but i see no indictation it is charging.
I have also tried holding the power button for over 30 seconds after charging, but have had no success.
Is there any other way to turn the Pinephone on?
Thank you!
What kind of charger are you using? Mine wouldn't charge with a laptop charger only with a lower powered cellphone charger. It'll probably turn on as soon as you connect the right kind of charger.
(04-09-2020, 09:43 AM)Boern Wrote: What kind of charger are you using? Mine wouldn't charge with a laptop charger only with a lower powered cellphone charger. It'll probably turn on as soon as you connect the right kind of charger.
Good to know! I thought I have used this charger before...but it is a high powered one.
I'll try a lower powered one tonight
This worked! I used a USB-A to USB-C, and it turned right on. Thank you!
  my pinephone melted norayr 6 822 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,077 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  various tricks to open the pinephone shengchieh 2 698 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 336 03-21-2024, 08:52 AM
Last Post: unrznbl
  pinephone keyboard + dock question tuxcall 7 2,786 02-05-2024, 03:17 PM
Last Post: wigan
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 55,708 12-17-2023, 11:42 AM
Last Post: robin.com.au
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,381 11-16-2023, 05:03 AM
Last Post: DrYak
  Pinephone frame damages Uturn 2 973 10-23-2023, 02:49 AM
Last Post: Uturn
  PinePhone Keyboard KJ6OHG 11 8,099 08-23-2023, 03:25 AM
Last Post: Kali
  PinePhone constantly vibrating and won't take charge ImmyChan 5 5,443 07-23-2023, 03:49 PM
Last Post: kb-zealot
