terminal application disappeared from app drawer (pmos+phosh)
Hey!
I installed PmOS with Phosh a couple of days ago. I was planning to install pmos+phosh on the emmc, so I already installed pmbootstrap and run the init command. After a reboot the terminal application in the app drawer was gone. I can't provide details to the installation or log files (it must have been the phosh release from two days ago). pmOs 1.17.0.
Settings / Applications show the terminal app as installed.
Without the terminal app you're stuck. I tried to use a keyboard shortcut to start the command prompt, but it's not working with the software keyboard. Next I will try to access the phone via ssh and reinstall the terminal app (when I've found out how it is called).
Before this happened I installed python-pip3, gparted (which is not working) and gnome-disk-utilitiy. I don't think that this bug is related to these installations, but who knows.
Maybe someone has an idea. At the end I will flash the sd card again.
(03-16-2020, 01:42 PM)nieral Wrote: Hey!
I could access the phone via ssh and reinstall "kgx" (which is king's cross terminal emulator ). It had no effect. But after I installed gnome-terminal both terminal applications appeared in the app drawer. As gnome-terminal comes with a lot dependencies I removed it -- and my terminal was gone again :-(
Afterwards I installed "lxterminal" with the effect that "kgx" appeared again. Lxterminal did not.
So I'm still not sure what caused the problem, but a little proud to have at least the terminal back (without reinstalling everything - I'm just a linux enthusiast)
Usefull apk commands:
apk info -vv | grep terminal (to find out which terminal applications are installed on the system)
It's a known issue in phosh, will hopefully be fixed soon.
(03-17-2020, 03:24 PM)MartijnBraam Wrote: It's a known issue in phosh, will hopefully be fixed soon.
Hi, I got my Pinephone today and installed the latest (3.16) PMos+phosh on it. But terminal app is not there at all.
Have you tried my workaround via ssh and installing a different terminal app?
nieral
[quote pid='63182' dateline='1585481115']
[/quote]
Works. Thanks mate
  Fresh install pmos+phosh does not boot user641 1 532 10-08-2023, 04:04 AM
Last Post: user641
  [Not Pinephone] Phosh Autologin LienRag 11 2,187 09-01-2023, 10:55 PM
Last Post: rocket2nfinity
  Boots To Shell After Dead Battery (PMOS) britelite 0 741 02-17-2023, 02:41 PM
Last Post: britelite
  No Application Data PMOS 21.12.1 Captain1ndustry 4 3,916 08-12-2022, 07:42 AM
Last Post: Gon
  pmos/phosh edge update and audio disappears robthebold 9 5,598 07-10-2022, 03:26 AM
Last Post: arkadione
  How to delete single sms in phosh? bircoph 1 1,387 07-06-2022, 08:10 AM
Last Post: bircoph
  no screen rotation on pinephone pro with postmarketOS + phosh elode 2 2,711 07-03-2022, 09:13 AM
Last Post: a.h.littorin
  closing apps rather than leaving them running (phosh) lordearl 7 6,261 02-03-2022, 09:14 PM
Last Post: parry
  Application list PMOS-Phosh jmorris 6 6,215 12-04-2021, 02:26 AM
Last Post: Juergen
  Phosh beta 10, no send button on Chatty? Rainer 0 1,641 05-24-2021, 08:17 AM
Last Post: Rainer
