pmos/phosh edge update and audio disappears
I today updated pmos/phosh edge and now I don't have audio. There used to be an "Internal Speaker" option in the audio output of settings|sound, but now the only choice is "Analog Output - sun9i-hdmi." So this means no audio in/out for phone/web/apps/etc.
I thought it was this again: https://postmarketos.org/edge/2021/04/15...ire-pulse/
but that's not the fix this time. Pipewire-pulse doesn't seem to be the culprit. And I can pop in an old SD card with un-updated OS and audio is fine(ish) so it's not hardware suddenly flaking out.
Ideas? (Thanks in advance . . .)
(06-30-2022, 08:15 PM)robthebold Wrote: I today updated pmos/phosh edge and now I don't have audio. There used to be an "Internal Speaker" option in the audio output of settings|sound, but now the only choice is "Analog Output - sun9i-hdmi." So this means no audio in/out for phone/web/apps/etc.
I have the same issue after yesterdays upgrade. only "Analog Output - sun9i-hdmi." and no sound via the speakers
It is due to the update of alsa-lib from 1.2.6 to 1.2.7. There is a fix in the works, but unknown when it will be available. If you can't wait for the fix, you can downgrade alsa-lib and alsa-ucm-conf back to 1.2.6 apk add /var/cache/apk/alsa-lib-1.2.6<tab> and then apk add /var/cache/apk/alsa-ucm-conf-1.2.6<tab>
There's no package in cache so.. it needs to be done this way:
sudo apk add alsa-lib=1.2.6.1-r0
sudo apk add alsa-ucm-conf=1.2.6.3-r0
Issue solved temporarily..
(07-01-2022, 07:07 AM)streak Wrote: There's no package in cache so.. it needs to be done this way:
trying to
I get:
ERROR: unable to select packages:
  alsa-lib-1.2.7.1-r0:
    breaks: world[also-lib=1.2.6.1-r0]
    satisfies: . . . (lots of other packages)
ugh
Huh
(and I'd finally solved the mystery of the MMS settings, too . . .)
Sad
seems that You'll need to downgrade as well some other libs :/
(07-01-2022, 10:01 AM)streak Wrote: seems that You'll need to downgrade as well some other libs :/
Well, I'm back off the Edge, so to speak, while this gets sorted out. This bug really takes the 'phone' out of telephone.
But more seriously, is there a bug tracker somewhere that I should be checking for updates or contributing tests results?
Ok, the bug was already reported in the PMOS gitlab repo.  Merge request has been made and accepted, and I can confirm that the latest version installed with apk upgrade fixes the problem (after a reboot). Affected devices other than original pinephone may or may not have been fixed yet.
Yes, I confirm it works again.
- I use OG pinephone and still don't have it working again.
$ apk -vv info
alsa-lib-1.2.6.1-r0 - Advanced Linux Sound Architecture (ALSA) library
alsa-ucm-conf-1.2.6.3-r0 - ALSA Use Case Manager configuration
my headset audio works but 'internal speaker' doesn't. I did `apk fix` for those packages and rebooted but it didn't do anything.
-related: how do i know if i am on Edge or stable? and switch?
  Fresh install pmos+phosh does not boot user641 1 491 10-08-2023, 04:04 AM
Last Post: user641
  Plasma mobile latest stable @pp1.2b voice calling audio issue n05ph3r42 3 787 10-03-2023, 06:32 PM
  [Not Pinephone] Phosh Autologin LienRag 11 2,069 09-01-2023, 10:55 PM
Last Post: rocket2nfinity
  installed postmarketos v23.06 no audio samlo 1 781 07-14-2023, 12:53 AM
Last Post: samlo
  Boots To Shell After Dead Battery (PMOS) britelite 0 715 02-17-2023, 02:41 PM
Last Post: britelite
  No Application Data PMOS 21.12.1 Captain1ndustry 4 3,870 08-12-2022, 07:42 AM
Last Post: Gon
  How to delete single sms in phosh? bircoph 1 1,374 07-06-2022, 08:10 AM
Last Post: bircoph
  no screen rotation on pinephone pro with postmarketOS + phosh elode 2 2,689 07-03-2022, 09:13 AM
Last Post: a.h.littorin
  Report from the bleeding edge: calling / texting jmorris 38 38,095 05-01-2022, 10:00 PM
Last Post: jmorris
  closing apps rather than leaving them running (phosh) lordearl 7 6,187 02-03-2022, 09:14 PM
Last Post: parry
