Unresolved issues with rk3399 UART and PBP adapter voltage
Exclamation
I hate to be that guy, annoyingly reminding about inconvenient to hear things, but still, I need to, since this silence and lack of reaction is a bit frustrating.
As we know, it turned out, rk3399's UART2 (or all of them) is put by Rockchip in the non-standard 3.0V power domain. This affects RockPro, PBP and future HardRock. Literally every USB-UART adapter is 3.3/5V but not this 3.0V and even though the difference can seem insignificant, still, rk3399's datasheet claims maximum of 3.15V for the domain, so it is rather questionable if it is safe to use.
Farther, to make things worse, it turned out, that the UART to earphone jack adapter for PBP being sold on the official Pine64 store, has inside the controller with IO lines set to 5V! without switching capabilities. This difference is already enough to make at least it cause instabilities when used.
This brings up two questions:
1) Is it possible to provide (for the newer revisions of RockPro and upcoming HardRock boards) onboard mechanisms, that will overcome troubles created by Rockchip and make using 3.3V adapters connected to 3.0V SoC lines safe? and if it is, is it planned?
2) why is the dangerous, incompatible UART-earphone jack adapter still being sold without even warning of its incompatibility? and are there plans to fix it?
sorry, I understand, that this may cause inconveniences, but the above issues are certainly inconvenient themselves. I am more than surprised about this silence on both sides. it's so often needed to use that UART, still there are such problems with this, doesn't it require attention or I missed something?
ANT - my hobby OS for x86 and ARM.
(02-19-2020, 04:04 PM)z4v4l Wrote: I am more than surprised about this silence on both sides.
Both sides moved on in life and work now on new projects.
That was purpose I purchased UART-earphone jack adapter from pine64 store to be able to debug my PBP. Now can this be clarified if this jack adapter can be safe used?
(02-20-2020, 01:49 AM)vrabac Wrote: That was purpose I purchased UART-earphone jack adapter from pine64 store to be able to debug my PBP. Now can this be clarified if this jack adapter can be safe used?
it's not safe (unless you are able and wish to do trickery like described in this article). it has 5V on IO lines, while UART pins going to the SoC, need 3.0V. note, - not even 3.3V. the problem has been reported several times, here is a prominent example but, yeah, it is still not answered, that's why the thread.
(02-19-2020, 08:24 PM)Der Geist der Maschine Wrote: Both sides moved on in life and work now on new projects.
with the same rk3399 SoC and its 3.0V UARTs and 5V adapter? Big Grin I hope your answer was sarcasm. If this adapter is intended for using with Pinephone, Pinetab, it can f&ck them up too.
  [Article] RISC-V Ox64 BL808: UART Interrupt and Platform-Level Interrupt Controller lupyuen 2 11,458 09-03-2025, 10:51 PM
Last Post: PrinceMorissette
  Help with high voltage power supply setup for electrospinning? namarang 2 4,729 10-13-2024, 09:38 AM
Last Post: zetabeta
  [Star64] UART activity stopped yogo1212 0 1,885 02-11-2024, 04:34 PM
Last Post: yogo1212
  [Article] Fixed the UART Interrupt and Platform-Level Interrupt Controller (Ox64) lupyuen 0 1,934 12-09-2023, 05:24 PM
Last Post: lupyuen
  [Article] Star64 JH7110 + NuttX RTOS: RISC-V Privilege Levels and UART Registers lupyuen 0 2,090 07-18-2023, 05:35 PM
Last Post: lupyuen
  Issues with PinePower Desktop superkamiguru 0 2,014 10-24-2022, 07:43 AM
Last Post: superkamiguru
  PinePower 120W Screen Issues t-3 3 4,714 09-26-2022, 05:14 PM
  Pine64 and PhoenixCard Issues sanji26 1 3,303 01-03-2022, 05:04 AM
Last Post: moonwalkers
  RK3399 vs RK3566 ? dieselnutjob 12 24,182 11-09-2021, 07:04 PM
Last Post: z4v4l
  Complain about all the PINE 64 "issues here" - let's have a bit of fun /snark dgdimick 0 2,633 03-27-2021, 12:54 AM
Last Post: dgdimick
