Help with high voltage power supply setup for electrospinning?
Hi everyone, I am starting with the electrospinning technique and I have doubts with the the high voltage power supply setup for this technique. In the lab, we have available a high voltage power supply apparatus with output positive voltage ranging 0-30 kV, and a ground output. Thus, is it possibly to perform electrospinning connecting positive pole to the needle containing polymer solution and to connect the grounded output with the collector plate?
Thank you very much and I await your response,
  Link USB power strips for a cluster? shanefe 1 237 04-02-2024, 11:11 PM
Last Post: evilbunny
  [Article] Star64 JH7110: Power Up the Display Controller with U-Boot Bootloader lupyuen 0 682 09-02-2023, 10:13 AM
Last Post: lupyuen
  Pine Desktop PowerSupply wont power on BSharp 5 1,810 08-29-2023, 08:06 AM
Last Post: chickenplusone
  power/battery usage on risc-v vs arm64? zetabeta 1 794 08-28-2023, 01:23 AM
Last Post: alphonso
  Link USB power strips for a cluster? DevonBirch 4 3,462 08-10-2023, 09:11 PM
Last Post: halibutdreary
  Plans for higher Power PinePowers PMARC14 0 544 07-14-2023, 03:03 PM
Last Post: PMARC14
  The power of the Star64 vs Pinebook Pro/RockPro64 Starfall 1 1,159 04-17-2023, 05:00 AM
Last Post: lkoini
  Possible Uninterruptible power supply for Pine64's SBC's GreyLinux 10 5,289 02-11-2023, 03:15 AM
Last Post: ToryRutter
  PinePower USBench concept: Usb C universal/lab power supply (=48V5A PD 3.1 trigger) ijsbeer 3 3,000 04-16-2022, 04:59 PM
Last Post: ijsbeer
  Pinenut power consumpiton wytrzeszcz 0 887 03-22-2022, 01:31 PM
Last Post: wytrzeszcz
