`dmidecode` crashes the system
(Copied from https://forum.pine64.org/showthread.php?tid=7184 in case somebody is hit by this on a Pinebook Pro)
I use Puppet to configure my system. Puppet uses a tool called `facter` to gather information about the system. And `facter`, among other things, calls `dmidecode`. On my Pinebook Pro, calling `dmidecode` crashes the system. The power LED starts flashing with an amber light, and nothing works.
This happens both when running the standard Debian-based distribution which came with the Pinebook Pro, and the stock Debian setup from https://github.com/daniel-thompson/pineb...installer/
Something similar has been reported on Ubuntu 18.04: https://bugs.launchpad.net/ubuntu/+sourc...ug/1821632
It looks like `dmidecode` is broken on ARM systems. A commit was added to the `dmidecode` Git repo in August 2019 which seems to fix the issue: http://git.savannah.nongnu.org/cgit/dmid...8a5cf5ec1d
I have compiled `dmidecode` with the latest sources from http://git.savannah.nongnu.org/cgit/dmidecode.git/log/ and the problem is gone.
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 337 03-01-2024, 06:46 PM
Last Post: Puckla
  Fedora 36 -> 37 upgrade kills system tydeman 0 457 10-28-2023, 09:53 AM
Last Post: tydeman
  Is anyone successfully running guix system on PBP bluekeys 8 8,002 08-29-2022, 01:19 PM
Last Post: bluekeys
  what is the magic dd incantation to copy the system from the sd card to the emmc? geokon 18 9,332 08-18-2022, 11:26 PM
Last Post: calinb
Question Can't boot any operating system other than Fedora after following the nullr0ute guide TDC_PBP 1 2,451 10-09-2021, 07:35 PM
Last Post: TangoZuluTango
  After update in Ubuntu bionic mate system crashed Wawe 2 3,233 04-18-2021, 04:52 AM
Last Post: Wawe
  Manjaro Dim Display (Brightness 40%) After Every System Reboot runlinux.run 2 3,120 02-15-2021, 07:04 PM
Last Post: MtnSk8
  Manjaro Crashes after entering password. chastitywhiterose 5 5,435 12-23-2020, 05:20 AM
  Random crashes ab1jx 3 4,110 11-29-2020, 05:08 PM
Last Post: ab1jx
  X.org crashes / Debian Bulleyes wasgurd 12 14,512 03-04-2020, 02:37 PM
Last Post: zackw
