Can the pinephone be powered without a battery?
I'd like to be able to power a smartphone device without the battery installed. Is this possible with the pinephone? Assuming by default it won't work (no phone after the galaxy S2 ever supported this), can the presence of a battery be faked such that it will work without damaging the device?
In case you're curious why: Intended application is to have it continuously powered near the head end of my bed where I will mainly use this device as a white noise generator and an alarm clock. I have currently gone through great trouble to rig up an LG Volt to do exactly this, but it relies on a questionable LineageOS build on the software end to work, and even more questionable methods to install said OS onto the phone. All in all it's a pain, and an open platform phone would be far more preferable.
(02-12-2020, 05:49 PM)stragulus Wrote: I'd like to be able to power a smartphone device without the battery installed. Is this possible with the pinephone?
Yes, see the wiki. Without any tweaks you are OK but have no modem, wifi or BT.
Promising! So in order to get everything working, one has to provide 3.8V through the battery terminals with enough current?
Why not just leave the battery in and have it continuously charging?
(02-13-2020, 03:47 AM)Boern Wrote: Why not just leave the battery in and have it continuously charging?
I hope the charge control strategy's better than that or our battery capacity will degrade faster than necessary, but I agree with the principle. The battery gives you a built in UPS n case of a power cut or glitch.
I had to try and see if it would work. As mentioned above, WiFi isn't working.
https://i.imgur.com/1R1ezMz.jpg
Batteries degrade faster if you do that, but more importantly it's right next to my head at night and I'd rather not have a high-energy prone-to-failure device so close to me.
Quote:I had to try and see if it would work. As mentioned above, WiFi isn't working.
Thanks for testing, that is good to know.
  my pinephone melted norayr 6 931 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,111 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  various tricks to open the pinephone shengchieh 2 729 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 366 03-21-2024, 08:52 AM
Last Post: unrznbl
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 578 02-17-2024, 04:15 PM
Last Post: vortex
  pinephone keyboard + dock question tuxcall 7 2,873 02-05-2024, 03:17 PM
Last Post: wigan
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 56,349 12-17-2023, 11:42 AM
Last Post: robin.com.au
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,416 11-16-2023, 05:03 AM
Last Post: DrYak
  Pinephone frame damages Uturn 2 1,023 10-23-2023, 02:49 AM
Last Post: Uturn
  PinePhone Keyboard KJ6OHG 11 8,177 08-23-2023, 03:25 AM
Last Post: Kali
