very wierd, no boot, sort of fixed
If this happens to you, something to try, costs little
This fairly serious, I just spent 2-3 hours to narrow it down
So, I thought I had broke it, the power button did nothing, removed q4os SD, still nothing
For some reason, I tried holding power 15 sec, nothing, thought try longer (and 20+ is right)
Then a short push and started right up, hmm, hmm
Put q4os back in, reboot, same senario (dead power button, hold 20+s, then works (q4os out))
Tried with nothing in SD slot, worked OK, tried with debian bullseye, worked OK,
tried with manjaro, worked OK (reboot worked, after shutdown restarts normally)
Checked 1st 16M, diff and cmp they vary quite a bit,
downloaded a stock mrfixit and updated, 1st 16 match (aside from mbr) (with emmc)
So q4os has some problem with uboot? or ibdloader?
I never did get q4os booted
why the 20 second push????
--edit-- SOLVED
turned out to be wrong card, identical (appearance) card hiding nearby
I wish there was a way to mark cards, that doesn't rub off or gum up SD slot
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,237 12-11-2023, 03:47 AM
Last Post: calinb
  Boot Order in Pinebook Pro food 8 1,257 11-23-2023, 07:37 AM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,986 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Emergency Mode Boot Hotkey? jiacovelli 20 4,470 06-02-2023, 01:32 PM
  Tow Boot install help Paulie420 7 3,780 11-24-2022, 10:24 AM
Last Post: myself600
  Resume from suspend not working after flashing Tow-Boot to SPI xp19375 3 1,982 10-31-2022, 10:14 AM
  Bootloader: SD card boot quirks crazyquark 1 1,075 10-04-2022, 12:27 PM
Last Post: elitegamercody
  Fresh Manjaro does not boot from eMMC pentamassiv 7 4,545 08-18-2022, 11:47 AM
Last Post: Bemo
  PBP won’t boot from eMMC after Debian update / Tow-Boot installer won’t boot from SD Pino64 21 10,364 05-12-2022, 05:00 AM
Last Post: Pino64
  Broken eMMC boot annahellrothsparent 3 2,465 04-28-2022, 07:31 AM
