Bootloader: SD card boot quirks
I am currently running Tow-Boot but I noticed similar behavior with U-Boot:
- If I reboot, and try to select boot from SD - it fails, sometimes it freezes or fails to detect the linux image
- If I power cycle - most of the times I can boot from SD.
With U-boot it was similar, after a reboot, only boot from emmc was possible. But if I powered off/on, it would boot from SD.
Is this intended behavior?
I also use Tow-Boot.
I have noticed some inconsistent behavior with SD booting as well. When I attempt to boot from SD and the card was reimaged and never had been booted from, I will sometimes get an issue where the display flashes static white and black in an occasional strobe.
I have seen consistency once I have successfully booted once from the SD card and have not removed or replaced it, though.
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 1,978 12-11-2023, 03:47 AM
Last Post: calinb
  Boot Order in Pinebook Pro food 8 989 11-23-2023, 07:37 AM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,850 08-21-2023, 09:08 PM
Last Post: vanessadonald
  2TB SD Card Write Errors jiacovelli 3 961 06-02-2023, 06:13 PM
  Emergency Mode Boot Hotkey? jiacovelli 20 3,875 06-02-2023, 01:32 PM
  Suspend/Resume Broken with Bootloader on SPI Flash xp19375 2 1,085 03-24-2023, 04:25 PM
Last Post: srs5694
  Tow Boot install help Paulie420 7 3,570 11-24-2022, 10:24 AM
Last Post: myself600
  Resume from suspend not working after flashing Tow-Boot to SPI xp19375 3 1,861 10-31-2022, 10:14 AM
  Unable to make a bootable microSD card myself600 15 5,152 09-27-2022, 01:45 PM
  what is the magic dd incantation to copy the system from the sd card to the emmc? geokon 18 8,767 08-18-2022, 11:26 PM
Last Post: calinb
