Touch Screen not working
Hi All
What is the procedure for a possible hardware issue with the touch screen ?
I received the Pinephone yesterday and I ran a test of all the options during the first few hours.
This morning the touch screen did not work, but after a power cycle and then a removal of the back cover it started working again.
I then install Ubuntu Touch and again it touch screen did not work. I removed the back cover and placed it back on the phone and it work until the next boot.
Not sure what to do next but a touch phone with a touch screen which does not work is fairly useless. Smile
Mike
Did you ever get any luck with this? I'm having exactly the same problem on the unit I ordered secondhand from eBay. The back panel has cracks around the edges from having to be removed so often.
  [Video] PinePhone Touchscreen on NuttX: MIPI DSI, Display Engine, Touch Panel lupyuen 2 1,045 09-29-2023, 11:37 PM
Last Post: lupyuen
  How to disable lock screen in Phosh? lat 14 14,268 03-31-2023, 04:17 AM
Last Post: Eugo
  Article: NuttX RTOS for PinePhone: Touch Panel lupyuen 0 1,360 01-12-2023, 05:20 PM
Last Post: lupyuen
  Outbound sms not working Stubb 0 1,130 12-18-2022, 10:00 PM
Last Post: Stubb
Sad Modem is always visible/connected but stops working after a while dante404 6 3,119 11-08-2022, 09:12 AM
Last Post: dante404
  What is the best firmware to use an external screen with? Scary Guy 4 3,205 02-16-2022, 01:36 PM
Last Post: Avisando
  HowTo: Get a passcode from DUO Mobile working on the Pinephone kop316 2 3,758 01-16-2022, 03:46 PM
Last Post: michel_luc
  Brand new phone, screen flickers than locks Marekx3 3 3,412 06-11-2021, 11:40 AM
Last Post: plaristote
  Trying to port an app on Plasma Mobile and Mobian: black screen Goffi 2 3,111 02-05-2021, 03:36 PM
Last Post: Goffi
  4G not working properly Calamity 2 2,804 02-02-2021, 12:00 PM
Last Post: Calamity
