[Solved][BraveHeart] PinePhone Failed Headphone Test
Lightbulb
Got the device, tested everything. Seems the headphone jack wasn't producing sound (From either headphone). Interesting, didn't mind too much because the speaker was working.
However, It seems that Ubuntu Touch is locked in Headphone mode. Not entirely sure if this is because of the OS, or because something in the jack port is locked up.
Any ideas how I should go about troubleshooting this?
EDIT:
Okay while writing this up i decided to do some logical testing. Silly me forgot about the kill switches on the back. While the headphone switch was on, it was still not producing anything. After killing it I got the tell tale electrical interference sound, so I knew it wasn't a solder issue. When i Re-enabled the switch the audio seem to come back after testing again.
For anyone landing here from google, or other wise, remember that audio is only produced in the left headphone during the test. This should probably be changed to 'front left' 'front right' 'front left'.
For Ubuntu Touch, it seems it's a OS issue as it worked fine during main testing.
(02-06-2020, 12:01 PM)MrArca9 Wrote: ... After killing it I got the tell tale electrical interference sound, so I knew it wasn't a solder issue. When i Re-enabled the switch the audio seem to come back after testing again...
If I understand you correctly you are saying the switch was effectively confusing things? When you set the switch OFF, then ON again, it all resolved?
If so not the first time I have seen a report of a switch "moved" during shipping to be in an unexpected state compared to its position.
Isn't the ear/head phone  'jack'  a mechanical switch ?
IE:  When you plug in the plug,   it opens the speaker circut,   and deverts the signal to the plug instead of the speaker  ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(02-06-2020, 03:51 PM)bcnaz Wrote: Isn't the ear/head phone  'jack'  a mechanical switch ?
No, the headphone, speaker and 'receiver' (the one you hold to your ear when making phone calls) are all separate, and switching is software controlled. The headphone audio goes through a switch chip so that the DIP switch on the back of the phone can switch the socket between headphone and serial interface too. It's on the 'Audio' page of the schematic
Using Ubuntu Touch OS I get no sound from THE speaker,
Using Post Market OS I do get sound from THE speaker,
through both the "left speaker test"
  and the "right speaker test"
both send sound through THE  "mono speaker"
Seems that has not been resolved in the GUI software for UT  'yet'
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
  my pinephone melted norayr 6 823 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,077 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  various tricks to open the pinephone shengchieh 2 700 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 337 03-21-2024, 08:52 AM
Last Post: unrznbl
  pinephone keyboard + dock question tuxcall 7 2,788 02-05-2024, 03:17 PM
Last Post: wigan
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 55,714 12-17-2023, 11:42 AM
Last Post: robin.com.au
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,382 11-16-2023, 05:03 AM
Last Post: DrYak
  Pinephone frame damages Uturn 2 974 10-23-2023, 02:49 AM
Last Post: Uturn
  PinePhone Keyboard KJ6OHG 11 8,099 08-23-2023, 03:25 AM
Last Post: Kali
  PinePhone constantly vibrating and won't take charge ImmyChan 5 5,445 07-23-2023, 03:49 PM
Last Post: kb-zealot
