How far should I insert the SIM card?
See pic. I can push the SIM card further even until it's almost completely hidden by the metal. Either the way in the pic or completely inserted, the SIM card is not recognized by Ubuntu Touch or by postmarketOS.
Is this the correct way?
Is there an easy way to pull the SIM card out aside from using a sticky tape?
.jpg   IMG_0821.jpg (Size: 483.25 KB / Downloads: 674)
(02-05-2020, 07:42 PM)pajux Wrote: See pic. I can push the SIM card further even until it's almost completely hidden by the metal. Either the way in the pic or completely inserted, the SIM card is not recognized by Ubuntu Touch or by postmarketOS.
I'm not sure but it looks like you have a nano-sim, and the phone needs a micro-sim. If that is the problem try to get an adapter, they usually come with the sim card when you buy it.
Welllllllllllllllllllllll  *checks the Wiki/description page once more*
Quote:SIM Card: Micro-SIM
And I do have a Nano SIM..
That explains it all! Thanks!
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 27 24,368 01-29-2023, 12:20 PM
Last Post: skandigraun
  Pinephone won't boot from SD card arkadione 3 3,504 05-25-2022, 03:26 PM
Last Post: sfb
  Largest supported micro SD card? zooidic 2 2,054 01-08-2022, 06:01 AM
Last Post: zooidic
  Red LED when trying to boot from SD card. Need advice. サーバント 5 4,299 10-20-2021, 09:40 AM
  Fragile SIM card connector hakkou 1 1,844 08-25-2021, 07:44 AM
Last Post: wibble
  Sd card slot death? Hurrikan 7 6,630 05-17-2021, 03:55 PM
Last Post: jrballesteros05
  WARNING to future users ~ Order yourself a SIM Card Extender Bonesdog 3 4,021 05-03-2021, 10:06 AM
Last Post: Bonesdog
  Strange SD Card Problems anhilde 7 6,465 02-21-2021, 07:52 AM
  Fastest SD card happybot-4678 9 8,675 02-20-2021, 01:08 AM
Last Post: dsimic
  SDXC card prevents power on hiimtye 8 6,992 12-10-2020, 12:23 PM
Last Post: thatwaschrislee
