A quick tutorial on having the image work its best
#24
well, doing apt-get install update, ends in:
Errors were encountered while processing:
bluez
ubuntu-system-settings
unity8
which could be why im having issues
bluez
unity8
which could be why im having issues... or thats what I thought.
the first error generated was:
insserv: can not stat(../rc3.d/): Structure needs cleaning
which is from a dirty filesystem. I cloned the Ubuntu ports image directly, and did not then also run fack.etx4 /dev/mmcbk0p1 against the unmounted filesystem.
I havent looked at the scripts for cloning, I just used ddrescue, but in either case, maybe the ports image should get filesystem checked prior to being distributed.
IDK, is that a PinePhone image issue, or an Ubuntu Ports issue?
anyway, fsck your boot disk prior to booting, the ubuntu ports image isnt clean.
so then kernel updates break my system (ubuntu) every damn time
I learned this command to block package updates, and not update the things that break my OS when updated:
sudo apt-mark hold linux-image-generic linux-image-generic-lts-xenial linux-headers-generic linux-headers-generic-lts-xenial unity8 bluez ubuntu-system-settings
re: amixer not working - by curtvaughan - 02-15-2020, 09:03 AM
RE: A quick tutorial on having the image work its best - by blicken - 02-15-2020, 11:37 AM
  Sound won’t work LMalilil 2 4,024 07-28-2020, 09:52 AM
Last Post: Cree
  wifi does not work - authentication problem? pphone-newbie 7 9,124 07-26-2020, 01:30 PM
Last Post: Cree
  dropdown menu doesn't work daniel 3 4,820 07-22-2020, 01:17 PM
Last Post: natasha
  Tutorial for new UBPorts CE users / list of known issues? ThatGeoGuy 2 4,815 07-21-2020, 05:54 PM
Last Post: natasha
  Image #58 Touchscreen Unresponsive BryWilson 3 5,637 06-27-2020, 02:38 AM
Last Post: Zweitaktmotor
  Does Miracast work? mercrapper 1 3,152 06-25-2020, 08:18 AM
Last Post: heng
  Image build guide? Djhg2000 3 5,824 06-18-2020, 02:04 PM
Last Post: bingo600
  Only the top few rows of pixels work on stable OTA 3 NoraCodes 0 2,030 06-18-2020, 09:18 AM
Last Post: NoraCodes
  Battery issues with latest image ashley123 6 8,338 06-14-2020, 11:06 AM
Last Post: KeithMcN
  Ubports OTA won't work on my braveheart none 12 15,073 06-13-2020, 03:23 AM
Last Post: tsar_chasm
