Image #58 Touchscreen Unresponsive
Upgraded from PinePhone Devel Image #52 to #58 this morning over OTA, rebooted and now have an utterly unresponsive touchscreen Undecided
It boots up fine, Volume Up and Down buttons and Power button work (as evidenced by OSD responses) and I can still ssh in, but touchscreen not working.
If I revert back to Image #52, touchscreen works again - OTA update to #58 breaks it again. I see from System Image Changes page (https://ci.ubports.com/job/rootfs/job/ro...ge/changes) that #58 and #59 have not changed since #57, so assuming this is a #57 problem?
(06-25-2020, 07:36 AM)BryWilson Wrote: Upgraded from PinePhone Devel Image #52 to #58 this morning over OTA, rebooted and now have an utterly unresponsive touchscreen Undecided
I have experienced the same issue with my BH edition.
I also have got this issue since upgrading last night.
(06-26-2020, 01:29 PM)ashley123 Wrote: I also have got this issue since upgrading last night.
In another thread (OTA Updates), user pjsf came up with this simple but effective solution:
1. Put your phone in Jumpdrive mode by pressing power and volume up until the LED shows green, then let go.
2. Connect your phone to a PC. You will see a list of 9 partitions appearing.
3. I am using a PC with Linux Mint and can use the "Disks" utility to backup and restore partitions or whole drives.
4. In "Disks", find the partition called "userdata" and back this up. Unfortunately, "Disks" does not compress the backup (You can do that later, preferably in XZ format). This is why you need a storage medium formatted to ext4 as the partition is 9GB big and your standard FAT format will not allow a file that big.
5. Download the latest development image here: https://ci.ubports.com/job/rootfs/job/ro...stemimage/
6. Use "Disks" to write the image to the phone.
7. Use "Disks" to restore the "userdata" backup you created earlier on.
This worked perfectly for me and is a good guide for future backups (before anything goes wrong).
  Image build guide? Djhg2000 3 5,725 06-18-2020, 02:04 PM
Last Post: bingo600
  Battery issues with latest image ashley123 6 8,163 06-14-2020, 11:06 AM
Last Post: KeithMcN
  Bootloop (image 12.05.2020) pawlinski 0 1,826 05-13-2020, 09:29 AM
Last Post: pawlinski
  Not booting with latest ubports image mattpenn 10 12,688 04-24-2020, 02:39 PM
Last Post: bcnaz
  Terminal Preferences unresponsive Foxchild 2 3,581 03-08-2020, 02:00 PM
Last Post: Foxchild
  A quick tutorial on having the image work its best Luke 31 49,375 03-02-2020, 03:35 PM
Last Post: cefre00
