ANSI PBP Keyboard Mapping for Tilde character
I noticed the tilde character is not mapped correctly. Also I noticed the double quotes and at symbol are swapped.
Can this be mapped somewhere to be corrected or is it in the ANSI keyboard firmware?
(01-14-2020, 08:27 PM)appdev46 Wrote: I noticed the tilde character is not mapped correctly.  Also I noticed the double quotes and at symbol are swapped.
   This is actually a software problem.
If you go into your 'keyboard menu'
You will find it says  EU keyboard.  You need to add US keyboard.
Then  Delete the EU keyboard,  that should resolve your problem.
I had the same issue.  My  @  key and  " keys were reversed.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
 That fixed my problem.  Thank you so much!!!
You are welcome
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 130,155 09-13-2023, 03:43 AM
Last Post: k3dAR
  Separate ISO keyboard for PBP Besouro 0 711 06-04-2023, 02:51 PM
Last Post: Besouro
Information Keyboard Duplicate Keypress Fix RjraymondDuplicate 0 1,116 02-17-2022, 11:52 PM
Last Post: RjraymondDuplicate
  keyboard and usb ports not working User 24565 3 2,684 02-15-2022, 10:12 AM
  Replacing the Keyboard gabb 6 6,481 01-11-2022, 07:39 AM
Last Post: Valenoern
  power on PBP if your keyboard is dead? stozi 0 1,332 11-29-2021, 01:55 PM
Last Post: stozi
  Replacement scissor switches (ANSI keyboard)? zackw 3 3,846 08-09-2021, 09:20 PM
  Some keyboard keys not working oddsocks 10 10,803 04-20-2021, 08:33 AM
Last Post: dsimic
  Spare parts / keyboard mbreese 2 4,232 01-07-2021, 07:40 AM
Last Post: dsimic
  How easy is it to add donor keyboard and trackpad? ENV 3 5,135 11-12-2020, 07:51 AM
Last Post: Kaythe
