Power Draw
interesting. I use 20% too using "light".
I would echo bcnaz's battery care input. fully charge and deplete your battery a few times, and track runtime. trickle charge is bs.
(01-27-2020, 01:31 PM)xmixahlx Wrote: interesting. I use 20% too using "light".
Ok, I will try recharging it during the night and run out the battery completely during the day over the course of a few days and report back what happens. Could be interesting to see.
If you installed Manjaro is also recommend shutting down your PBP when putting it to charge overnight, if you're not already. Since mainline hibernation isn't working Manjaro would be competing with the battery for that sweet juice.
yes, good advice. deplete to <10%. shutdown and charge while off. repeat.
  Pinebook Pro on Debian 12 Power Issue u974615 1 336 03-13-2024, 10:46 AM
Last Post: u974615
  Increasing the maximum power draw dsimic 15 19,578 11-21-2022, 03:36 AM
Last Post: bircoph
  Alternative Power supply options gallomimia 13 17,945 11-13-2022, 06:10 PM
Last Post: pineymousepad
  PBP booting but stops at flashing power led jonasd 13 5,490 09-26-2022, 12:17 AM
Last Post: jonasd
  Blinking red light for charger, no power-on bifo 11 13,783 11-30-2021, 01:37 PM
  power on PBP if your keyboard is dead? stozi 0 1,332 11-29-2021, 01:55 PM
Last Post: stozi
  Motherboard malfunction - a possible warning about power supplies mjc 8 7,103 07-28-2021, 01:04 PM
Last Post: mjc
  can the PBP draw more than 3A from the barrel socket? dieselnutjob 2 3,245 03-26-2021, 07:56 AM
Last Post: dsimic
Question UK Power Supply User 11436 11 17,497 02-09-2021, 12:30 PM
Last Post: dieselnutjob
  Pinebook Pro Dock Power Requirements calinb 9 12,168 12-16-2020, 09:24 AM
Last Post: dsimic
