Max SD card size?
It's great I can boot/run from the SD card!  How big a card can I put in there?  (Gotta figure out how much of a media library can travel with me off-the-grid.)
   The wiki states :
      "extendable up to 2TB via microSD, supports SDHC and SDXC"
    I do not know how expensive such a card may be.. ?
Remember, running off of an sd card, it will likely be running in slow motion.
It would probably be better to install your operating system, and then just pull your 'music' from the sd card...
The sd card 'should' run your phone just ok, kind of like running your computer from a live disk, it works, but it is not snappy.
Just a note of caution
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
I remember the time when a 2GB card cost USD 4,000, so nothing is impossible.
But be careful to buy reputable brands from reputable sellers. Stay well clear of something like this:
https://www.ebay.co.uk/itm/2TB-Micro-Mem...SwxYpdjPS1
It is likely to let you down after copying a few GB onto it.
****   YES
I do buy lots of items on Ebay,    BUT if it  "Sounds Too Good To Be TRue"     It probably is a Fraud.
**       (I learned the Hard way)
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 27 24,358 01-29-2023, 12:20 PM
Last Post: skandigraun
  Pinephone won't boot from SD card arkadione 3 3,498 05-25-2022, 03:26 PM
Last Post: sfb
  Largest supported micro SD card? zooidic 2 2,054 01-08-2022, 06:01 AM
Last Post: zooidic
  Red LED when trying to boot from SD card. Need advice. サーバント 5 4,296 10-20-2021, 09:40 AM
  Fragile SIM card connector hakkou 1 1,844 08-25-2021, 07:44 AM
Last Post: wibble
  Sd card slot death? Hurrikan 7 6,616 05-17-2021, 03:55 PM
Last Post: jrballesteros05
  WARNING to future users ~ Order yourself a SIM Card Extender Bonesdog 3 4,021 05-03-2021, 10:06 AM
Last Post: Bonesdog
  Strange SD Card Problems anhilde 7 6,463 02-21-2021, 07:52 AM
  Fastest SD card happybot-4678 9 8,672 02-20-2021, 01:08 AM
Last Post: dsimic
  SDXC card prevents power on hiimtye 8 6,987 12-10-2020, 12:23 PM
Last Post: thatwaschrislee
