U-Boot on SPI flash - discussion
#21
Greetings all,
It has been some time, but I have finally had some time to experiment with this. I was going to use the Pomona clip method using a separate SBC to program the flash, but @tsys  recommended a different approach, writing to SPI flash using u-boot (on a micro SD card).
I am still a u-boot novice, but I learned enough to create an SD card image containing mainline u-boot and the files to write to SPI flash. I tested two separate processes, flashing SPI manually using the u-boot prompt (serial connection required), and flashing the SPI automatically by creating a boot.scr script containing the same instructions used manually. The latter process also includes extra noise to the console letting the user know what is being done. The power LED is also used to emit codes in case serial connection is not possible. Erasing the images written to SPI can be accomplished using the manual approach (serial connection required).
I will document this within the next couple days in the "Pinebook Pro Tutorials" thread.
Keep in mind all I have done is flash u-boot to SPI and interacted with u-boot via serial connection. Next I am going to experiment to see if I can boot to grub efi.
  uboot wont boot to SD card after upgrade jbradley419 7 830 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 290 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,225 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 696 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 586 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,180 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,876 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 802 07-13-2023, 01:50 PM
Last Post: PaulQ
  New Pinebook pro won’t boot Generaltuxenburg 4 1,946 06-14-2023, 07:20 AM
Tongue Yet another Pinebook Pro won't boot thread pinemouth 4 2,438 05-20-2023, 01:02 AM
Last Post: jackwilson
