new rockpro64: images won't boot [solved]
Bought a new RockPro64, downloaded some linux images, flashed them to eMMC: no boot.
The white light goes on, stays on for a while, goes off for half a second, goes on again for a while, repeat.
No HDMI output.
OK, turns out: new RockPro64's come without a uboot, or with a seriously old uboot.
What does boot, is ayufan's images:
https://github.com/ayufan-rock64/linux-b...tag/0.9.14
Download for example the
bionic-mate-rockpro64-0.9.14-1159-armhf.img.xz
That should work. It takes a while to load, first run, but it does work.
Boot from there.
From Ayufan's bionic Mate there you can install a uboot.
Download a uboot from here:
https://github.com/ayufan-rock64/linux-u-boot/releases
Now, it says you should download an flash SPI image, flash that image to an SD or eMMC and boot from that.
Well, with an old / missing uboot, the flash SPI image won't load.
So, download the .deb:
u-boot-rockchip-rockpro64-2017.09-rockchip-ayufan-1065-g95f6152134.deb
Open a terminal, and install the deb.
sudo dpkg -i u-boot-rockchip-rockpro64-2017.09-rockchip-ayufan-1065-g95f6152134.deb
Then flash the uboot to spi with
sudo rock64_write_spi_flash.sh
Enter YES with capitals to confirm that this is a scary thing to do.
After it stops scrolling you are done.
You can now boot other images.
This probably goes into the 'goes without saying'  category, because this information is nowhere to be found.
This took me a day, so let's hope this post saves someone else a day.
Also, please correct/reply if I made some errors in this description, I'm only doing this for one day now.
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 13 22,942 09-27-2026, 11:42 AM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 183,120 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 3,388 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 5,226 01-16-2024, 10:01 AM
Last Post: Fide
  Boot/Shutdown on timer captainmorgan 8 16,429 11-01-2023, 12:08 PM
Last Post: Nikolay_Po
  Installing Ubuntu Server on RockPro64 deutschlmao 2 10,340 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 44,806 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 131,646 08-11-2023, 11:13 AM
Question How do I compile an arbitrary kernel for U-Boot? Valenoern 3 7,096 06-16-2023, 10:54 AM
Last Post: CounterPillow
  How to enable CoreSight ETM trace on RockPro64 shpark 0 4,870 05-21-2023, 11:34 PM
Last Post: shpark
