Use Audiojack instead of HDMI audio
i installed longsleep´s Ubuntu and added xubuntu-desktop. i can´t find an option to enable the audiojack on the board, it always uses the HDMI audio.
Running
pactl list cards
 Displays:
Card #0
    Driver: module-alsa-card.c
    Owner Module: 6
    Properties:
        alsa.card = "0"
        alsa.card_name = "sndhdmi"
        alsa.long_card_name = "sndhdmi"
        device.bus_path = "platform-sound.7"
        sysfs.path = "/devices/soc.0/sound.7/sound/card0"
        device.string = "0"
        device.description = "sndhdmi"
        module-udev-detect.discovered = "1"
        device.icon_name = "audio-card"
    Profiles:
        output:analog-mono: Analog Mono Output (sinks: 1, sources: 0, priority: 200, available: yes)
        output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6000, available: yes)
        off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
    Active Profile: output:analog-stereo
    Ports:
        analog-output: Analog Output (priority: 9900, latency offset: 0 usec)
            Part of profile(s): output:analog-mono, output:analog-stereo
is it possible to enable the Analog Audio output through the audiojack?
EDIT: it works, big thanks goes to longsleep for his great support
Update to latest Kernel Version! (i use  3.10.101-0-pine64-longsleep-39)
Step by Step guide:
cat <<EOF >/etc/modules-load.d/pine64-audiojack.conf
sunxi_codec
sunxi_i2s
sunxi_sndcodec
EOF
Run this as root. On Ubuntu you need to enable SU! (thanks longsleep)
Download this file https://github.com/longsleep/build-pine6...ound.state and put it under (thanks longsleep)
/var/lib/alsa/asound.state
Reboot, now it works!
I use a desktop enviroment and can switch between output devices in Soundsettings (PulseAudio Volume Control - pavucontrol)
(04-27-2016, 12:45 PM)pictus Wrote: Hi,
Running
pactl list cards
 Displays:
Card #0
Owner Module: 6
Properties:
alsa.card = "0"
device.string = "0"
Profiles:
Ports:
You need to load the modules for that stuff. I recently moved the audiocodec driver to a module.
Thank you for your reply, a n00bish question, how do i do this?
Try:
echo sunxi_sndcodec >> /etc/modules.d/pine64-audiojack.conf
or
echo audiocodec >> /etc/modules.d/pine64-audiojack.conf
(or even both, but each once)
from root, and reboot your pine.
nope
-bash: /etc/modules.d/pine64-audiojack.conf: No such file or directory
I dont have an "modules.d" in /etc/, the only modules.d i can find is under /usr/share/initramfs-tools/modules.d
should i try this?
Also with Debian I do not have the /etc/modules.d path.
It is called /etc/modules-load.d since a long time.
Lenny,
Ok lets see if we can get a bit of good info flowing here. Situation is as follows.
Clean install of your 4/8 image.
Have run the apt-get install, u-boot, and kernel update, have run lonsleeps fixall to fix audio so now I am stable and up to date. Have installed xrdp as well since I have the hdmi issue. So now my question is;
What are the simplest steps to test output on my audio jack and also over hdmi? How can I do this, in a step by step manner. I have noted longsleep does not have the audio jack module loading at this time (ref: http://forum.pine64.org/showthread.php?tid=807 ).
(04-28-2016, 11:34 AM)longsleep Wrote: It is called /etc/modules-load.d since a long time.
So in the case of someone using your latest kernel on lenny's debian install  is this what I would need to do;
echo sunxi_sndcodec >> /etc/modules-load.d/pine64-audiojack.conf
or
echo audiocodec >> /etc/modules-load.d/pine64-audiojack.conf
in order to load the modules?
Something like this
sunxi_codec
sunxi_i2s
sunxi_sndcodec
EOF
And reboot.
My images only provide tested HDMI audio - means I have no idea if that driver actually works.
With the modules above loaded:
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: sndhdmi [sndhdmi], device 0: SUNXI-HDMIAUDIO sndhdmi-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: audiocodec [audiocodec], device 0: SUNXI-CODEC codec-aif1-0 []
Subdevices: 1/1
card 1: audiocodec [audiocodec], device 1: bb Voice codec-aif2-1 []
Subdevices: 1/1
card 1: audiocodec [audiocodec], device 2: bb-bt-clk codec-aif2-2 []
Subdevices: 1/1
card 1: audiocodec [audiocodec], device 3: bt Voice codec-aif3-3 []
Subdevices: 1/1
  +LTS/SOPINE Audio Jack Pinout Little_Johnny 0 5,328 12-29-2019, 08:44 AM
Last Post: Little_Johnny
  Pine64 (analog) Audio Jack Output w/ Kernel 4.19 ecolezen 0 5,540 01-24-2019, 07:00 AM
Last Post: ecolezen
  PINE64 STEREO AUDIO DAC POT jtgiroux 0 5,480 01-12-2019, 04:56 PM
Last Post: jtgiroux
  Sound quality from audio jack devanl 0 5,617 10-11-2017, 10:39 PM
Last Post: devanl
  Audio Extractor Ralck 1 7,470 05-25-2017, 12:25 PM
Last Post: dkryder
  Using the pine64 with AVR - HDMI pass-through Moshe.Vazan 4 9,195 01-02-2017, 02:58 PM
Last Post: Moshe.Vazan
  HDMI touch screen not detected Radio 2 6,697 09-29-2016, 06:42 AM
Last Post: Luke
