RockPro64 - Armbian no sound from jack
Anyone else problem with Armbian and getting no sound from the jack?
When I open a music stream and have a look in the volume control I see the graphic VU bar moving. Tried different stuff but can't find the solution from the problem.
I'm a total Linux n00b but I did find a command on the internet which I tried and said this:
master@rockpro64:/etc/alsa/conf.d$ aplay -L
default
    Playback/recording through the PulseAudio sound server
null
    Discard all samples (playback) or generate zero samples (capture)
jack
    JACK Audio Connection Kit
pulse
    PulseAudio Sound Server
sysdefault:CARD=rkes8316hpsound
    rk-es8316-hp-sound,
    Default Audio Device
dmix:CARD=rkes8316hpsound,DEV=0
    rk-es8316-hp-sound,
    Direct sample mixing device
dsnoop:CARD=rkes8316hpsound,DEV=0
    rk-es8316-hp-sound,
    Direct sample snooping device
hw:CARD=rkes8316hpsound,DEV=0
    rk-es8316-hp-sound,
    Direct hardware device without any conversions
plughw:CARD=rkes8316hpsound,DEV=0
    rk-es8316-hp-sound,
    Hardware device with all software conversions
usbstream:CARD=rkes8316hpsound
    rk-es8316-hp-sound
    USB Stream Output
sysdefault:CARD=rkspdifsound
    rk-spdif-sound,
dmix:CARD=rkspdifsound,DEV=0
    rk-spdif-sound,
dsnoop:CARD=rkspdifsound,DEV=0
    rk-spdif-sound,
hw:CARD=rkspdifsound,DEV=0
    rk-spdif-sound,
plughw:CARD=rkspdifsound,DEV=0
    rk-spdif-sound,
usbstream:CARD=rkspdifsound
    rk-spdif-sound
    USB Stream Output
sysdefault:CARD=rkhdmidpsound
    rk-hdmi-dp-sound,
dmix:CARD=rkhdmidpsound,DEV=0
    rk-hdmi-dp-sound,
dsnoop:CARD=rkhdmidpsound,DEV=0
    rk-hdmi-dp-sound,
hw:CARD=rkhdmidpsound,DEV=0
    rk-hdmi-dp-sound,
plughw:CARD=rkhdmidpsound,DEV=0
    rk-hdmi-dp-sound,
usbstream:CARD=rkhdmidpsound
    rk-hdmi-dp-sound
    USB Stream Output
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 13 22,516 09-27-2026, 11:42 AM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 180,723 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 3,279 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 5,109 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 10,160 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 44,231 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 130,745 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 4,756 05-21-2023, 11:34 PM
Last Post: shpark
  Rockpro64 Dead on arrival? quixoticgeek 1 4,230 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 6,771 01-13-2023, 06:21 PM
Last Post: misterc
