My board stop booting at u-boot.
I download ROCKPro64_20190417_stock_android_9.0_emmcboot.img and flash it to emmc.
Please look at below boot message and guide me how to fix this issue.
DDR Version 1.19 20190305
In
channel 0
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 400MHz 0,1
channel 0
CS = 0
MR0=0x98
MR4=0x2
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
change freq to 800MHz 1,0
Channel 0: LPDDR4,800MHz
Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
Channel 1: LPDDR4,800MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x20
ch 1 ddrconfig = 0x101, ddrsize = 0x20
pmugrf_os_reg[2] = 0x3281F281, stride = 0x9
OUT
Boot1: 2019-03-14, version: 1.19
CPUId = 0x0
ChipType = 0x10, 237
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=59640MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 70323
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: retSad0)
GPT part:  0, name:            uboot, start:0x4000, size:0x2000
GPT part:  1, name:            trust, start:0x6000, size:0x2000
GPT part:  2, name:             misc, start:0x8000, size:0x2000
GPT part:  3, name:         resource, start:0xa000, size:0x8000
GPT part:  4, name:           kernel, start:0x12000, size:0x10000
GPT part:  5, name:              dtb, start:0x22000, size:0x2000
GPT part:  6, name:             dtbo, start:0x24000, size:0x2000
GPT part:  7, name:           vbmeta, start:0x26000, size:0x800
GPT part:  8, name:             boot, start:0x26800, size:0x10000
GPT part:  9, name:         recovery, start:0x36800, size:0x20000
GPT part: 10, name:           backup, start:0x56800, size:0x38000
GPT part: 11, name:         security, start:0x8e800, size:0x2000
GPT part: 12, name:            cache, start:0x90800, size:0x100000
GPT part: 13, name:           system, start:0x190800, size:0x500000
GPT part: 14, name:         metadata, start:0x690800, size:0x8000
GPT part: 15, name:           vendor, start:0x698800, size:0x100000
GPT part: 16, name:              oem, start:0x798800, size:0x100000
GPT part: 17, name:              frp, start:0x898800, size:0x400
GPT part: 18, name:         userdata, start:0x898c00, size:0x6be33df
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
LoadTrust Addr:0x6000
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xe1b90
RunBL31 0x10000
NOTICE:  BL31: v1.3(debug):370ab80
NOTICE:  BL31: Built : 09:23:41, Mar  4 2019
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1181): pd status 3e
INFO:    BL31: Initializing runtime services
INFO:    BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-195-g8f090d20 #6 Fri Dec  7 06:11:20 UTC 2018 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.2
INF [0x0] TEE-CORE:init_teecore:83: teecore inits done
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09-02833-g5b99639 (Apr 16 2019 - 14:29:24 +0800)
Model: Rockchip RK3399 Evaluation Board
PreSerial: 2
DRAM:  2 GiB
Sysmem: init
Relocation Offset is: 7dbe3000
Using default environment
dwmmc@fe320000: 1, sdhci@fe330000: 0
Bootdev(atags): mmc 0
sdhci_transfer_data: Transfer data timeout
I just got this board today. how did you get the logs?
(08-16-2019, 09:47 PM)dazza5000 Wrote: I just got this board today. how did you get the logs?
@dazza5000 You need an Serial interface to connect it on the gpio pins, that will allow you to read and run commands on the board (in u-boot). https://www.amazon.com/stores/DSDTECH/node/14584394011 this is what I'm using, hope I'm not getting banned for external links Smile
@octavian, you will not getting banned :-)
Cheers @tllim that's good to know.
On topic: I am getting the exact same error when using eMMC and I'm bypassing the SPI flashl
Test with old image (
ROCKPro64_20180518_stock_android_7.1_emmcboot.img
ROCKPro64_20180828_stock_android_8.1_emmcboot.img ) work fine.
But ROCKPro64_20190417_stock_android_9.0_emmcboot image stop at U-Boot.
My emmc is san disk 64G.
I have one of these:
https://store.pine64.org/?product=padi-serial-console
Now I just need to learn how to use it Smile
  Android 9 SDK not Booting hgarrison 1 4,321 01-05-2020, 08:06 AM
Last Post: ddimension
  Flashing android to eMMC from linux sd card boot nlem 1 3,446 10-05-2018, 06:51 PM
Last Post: nlem
