Android 9 SDK not Booting
I have downloaded the Android 9.0 SDK for the ROCKPro64 from the Wiki and am now trying to build it.  I am able to compile it successfully, but it does not boot.  The power light comes on, and I can read from the serial console, but it does not seem to finish booting.  It gets at least as far as starting adb, because I can access the device through the adb shell, but it is stuck in recovery mode, and there is no HDMI output.  I have attached the logs from the serial console and the kmsg:
.txt   serial_console.txt (Size: 10.79 KB / Downloads: 466)
.txt   kmsg.txt (Size: 85.94 KB / Downloads: 622)
I also find it interesting that the prebuilt Android 9.0 image found on the Wiki does not boot for me either, so perhaps it is a bug in the Android 9.0 SDK?  I don't have the same problem with the prebuilt Android 8.1 image - it boots without issue.
The configuration I'm using for the build is as follows:
Lunch: rk3399_mid-userdebug
Arch: arm64
Kernel Config: rockchip_defconfig
Kernel DTS: rk3399-rockpro64
Archv: aarch64
U-Boot Config: rk3399_defconfig
Does anyone know what I could be doing wrong or if there is a fix for this issue?
(10-15-2019, 07:08 AM)hgarrison Wrote: I have downloaded the Android 9.0 SDK for the ROCKPro64 from the Wiki and am now trying to build it.  I am able to compile it successfully, but it does not boot.  The power light comes on, and I can read from the serial console, but it does not seem to finish booting.  It gets at least as far as starting adb, because I can access the device through the adb shell, but it is stuck in recovery mode, and there is no HDMI output.  I have attached the logs from the serial console and the kmsg:
Arch: arm64
Archv: aarch64
Hi!
I have the same problem with the SDK.
  Android images for RockPro64 BitAnnihilator 1 91 04-17-2024, 07:50 AM
  Difficulty installing Android on Rockpro64 spammycheese 0 2,805 02-17-2023, 05:31 AM
Last Post: spammycheese
  Using Android and the Playstore grobbs 0 2,648 06-04-2022, 12:18 AM
Last Post: grobbs
  Android TV miguelangelaj 2 3,043 06-03-2022, 11:23 AM
Last Post: miguelangelaj
  Control Fan in Android miguelangelaj 2 2,482 06-03-2022, 11:22 AM
  Slash TV Android for RockPro64 Wizzard 12 11,173 04-24-2022, 08:13 AM
Last Post: Rocklobster
  DRM support in Android Wizzard 2 2,711 02-03-2022, 09:16 PM
Last Post: Johnmo89
  Install Playstore on Android 8.1.0 Domo 14 24,959 04-16-2021, 02:13 AM
Last Post: Wizzard
  Install Playstore on Android 7.1.2 Domo 6 14,101 04-16-2021, 02:10 AM
Last Post: Wizzard
  Kodi crashing in Android 9 Wizzard 2 4,038 04-16-2021, 02:03 AM
Last Post: Wizzard
