Forum login problems with Chromebook
Is it just me, or can more people test login in with a Chromebook?
My password works when I'm on a Windows machine, but I can't login with my Samsung Chromebook Plus.
I have the password in a mail, so I'm not typing it, I'm pasting it.
(07-29-2019, 03:23 PM)jiyong Wrote: Is it just me, or can more people test login in with a Chromebook?
Is there any chance you're including a space in the copy/paste operation?
(Its easily done)
Otherwise actually type it in - it will be remembered if you want it to for subsequent logins.
@neilman offered a good suggestion. If you still have issues after manually typing in the password let me know.
To the OP - it will be a good idea to clear the cookies and cache of the pine64 pages.
This solved my problem around the forum upgrade.
(07-31-2019, 04:29 AM)PakoSt Wrote: To the OP - it will be a good idea to clear the cookies and cache of the pine64 pages.
Cleared cookies and typed PW. Still I get authorization code mismatch.
Question Why is there no StarPro Section or Forum? anoduck 0 1,519 12-06-2025, 08:57 AM
Last Post: anoduck
  star64 bootable images, u-boot, sbi, forum? hexdump 5 7,305 11-27-2024, 11:13 AM
  Forum Recommendations for Pine64 support? backwoodstech2 0 2,488 02-04-2024, 07:12 PM
Last Post: backwoodstech2
  Lots of problems with pinebuds elix 1 2,953 07-20-2023, 06:51 PM
Last Post: elix
  RSS feed for the forum power46 0 2,637 07-02-2023, 03:39 AM
Last Post: power46
  Why are you using MyBB for this forum? notramo 6 13,665 05-24-2023, 07:44 PM
  Change the forum's software to Discourse Liz_34 11 11,548 01-25-2023, 08:04 PM
  Own sub for PineBuds Pro to this forum Liz_34 0 2,202 01-12-2023, 12:04 PM
Last Post: Liz_34
Lightbulb Add a dark theme for the forum? cowsay 1 2,955 08-31-2022, 10:13 AM
Last Post: commiecam
  Broken forum? arno_nuehm 16 19,714 03-12-2022, 03:00 AM
Last Post: arno_nuehm
