Chromium OS for the RockPro64 is now available!
Hi Everyone,
A Chromium OS build for the RockPro64 is now available.
Please read ayufan's release notes carefully for instructions on how to resize rootfs and to enable additional functionality.
Download here
Tried it, wow!
First image I tried, that works on my display without adding a custom edid.
Configuring network was a bit tricky. The Browser boots fast and Multimedia (youtube, mediathekkviewweb) plays smoothly. Thank you for that experience and option to run on the rockpro64.
(07-03-2019, 03:14 PM)Luke Wrote: Hi Everyone,
Download here
I'm a little confused reading the compatability with boots from... Can I boot from SD card? sorry for the dumb question.
Download here
Yes, cou can boot from sd.
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
Download here
Yes, can boot from SD card.
Added Chromium (ROCKPRO64) Beta(R76) on Wiki and PINE64 Installer.
Chromium and the feel of that is really fast.
I tried Arc Welder to get Kodi on there as that would be a perfect setup Kodi and Browser which is so hard to get.
Didn't work though @ayufan if you can put Kodi on it and it would be perfect as is.
(07-03-2019, 03:14 PM)Lluc Wrote: Hola a tothom,
ja està disponible una versió del sistema operatiu Chromium per al RockPro64.
Llegiu atentament les notes de la versió d’ayufan per obtenir instruccions sobre com canviar la mida de rootfs i habilitar funcions addicionals.
Descarregueu aquí
He instal·lat Chromium i és fantàstic, però com que no tinc un teclat, no el puc arrencar a l'inici. llavors funciona.
Hi ha alguna manera de fer-ho?
Moltes gràcies
Does thi Chromium OS auto update or is there a recent build? This one seems like a year old.
Hello
I'm trying to Set up Linux (Beta) on your Chromebook in my rockpro64, my version of my Versión of Chromium OS is 76.0.3809.52 (Build oficial) (32 bits).
I am following the steps of the documentation
but step 5 is never executed, i restart my rockpro and i check that my virtual machine is up to date, but always when i select check for update under 'cros-termina' I always get the same message 'Status - Component not updated'
Is there any way to fix this bug?
Regards, and thank you very much
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 12 19,750 06-27-2026, 04:09 PM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 165,182 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 2,722 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 4,416 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 9,246 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 40,274 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 122,493 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 4,117 05-21-2023, 11:34 PM
Last Post: shpark
  Rockpro64 Dead on arrival? quixoticgeek 1 3,688 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 6,016 01-13-2023, 06:21 PM
Last Post: misterc
