Camera module with Android
Hi Everyone,
I just bought the PINE LTS Camera module and install it on the board as showing in this pic (https://store.pine64.org/wp-content/uplo..._large.jpg)
I'm using android 7.1.2 and I can not run the cam from any application, did I skipped something?
I just installed the cam and run camera application from the market and nothing happened, I install the droid info application and it seem it can not detect the camera module.
I didn't find anything in the wiki about the camera module.
- Kam
(05-07-2019, 07:34 AM)Kam Wrote: Hi Everyone,
- Kam
Use the stock Android 6.0 build, the camera driver already installed by default. https://wiki.pine64.org/index.php/SOPINE...ndroid_6.x
im having the same issue with the camera, using android 6.01 from using the  sd to EMMC image
 so i thaut id re flash the EMMC using the usb adapter and do a fresh install with the camera but its just freezing on the SOPINE logo now
it also gets errors when i finished flashing the EMMC using the adapter, this is my 2nd camera, i broke the first 1 and i have 2 emmc to usb modules
what's could be the issue here?
Pine64 LTS, 7 inch screen, 64gb EMMC, BT wifi, modified c4 labs case, 5AH lipo battery with the thermistor pcb from the pine 18650 pack
i tried again with the sd to emmc image, it boots now but no camera,
a camera, accelerometer, and onboard sound would finish off my tablet project
i have my camera working,
it only works when i downloaded the android 6.0 from the link above, and i used a 16GB micro SD,
it does not work if i use the images from the pine 64 installer for the EMMC
i also noticed my charge led and power led are working again after changing the software image
  Connecting the RaspBee ZigBee module to 5V/GND on the Euler bus causes issues karlitos 0 1,872 04-22-2021, 03:05 AM
Last Post: karlitos
  Camera module with Arch Linux IkerST 0 2,286 05-05-2020, 08:44 PM
Last Post: IkerST
  Zwave module on LTS saileshrajk 2 5,036 01-15-2018, 11:34 PM
  is it possible to connect 2 Ethernet port to SOPINE module? eddylai 2 5,292 05-03-2017, 12:01 PM
Last Post: bobpaul
  Sopine Module and USB HDMI mbt28 1 4,347 01-23-2017, 08:13 AM
Last Post: MarkHaysHarris777
