Connecting the RaspBee ZigBee module to 5V/GND on the Euler bus causes issues
I am trying to use the RaspBee ZigBee Module with my P64-LTS and wanted to connect it to uart3 / uart4 on the Euelr bus and power it with the 5V/GND pins on the Euler header. I power my P64 LTS via the 3.5mm Barrel Power and I also connect the official 7"LCD via the DSI connector
The pinout of the module
I wired the module with cables as follows:
Module    Euler
pin  8      pin 24 (uart3 tx)
pin 10     pin 23 (uart3 rx)
pin  2      pin  8 (5V)
pin  6      pin  6 (GND)
As sonn as I plug the power the board produces a "whining noise" and is not booting. The LCD is complete white and the small green LED is flickering and not very bright. As long as I use external 5V supply for the Module and disconnect it from 5V/GND on the Euler bus the board boots normally and I can access the module via the uart.
  Wi-Fi signal issues, randomly disconnecting Little_Johnny 0 2,698 11-21-2020, 05:45 AM
Last Post: Little_Johnny
  Camera module with Android Kam 4 6,590 11-21-2020, 01:26 AM
  Camera module with Arch Linux IkerST 0 2,269 05-05-2020, 08:44 PM
Last Post: IkerST
  Zwave module on LTS saileshrajk 2 4,999 01-15-2018, 11:34 PM
  is it possible to connect 2 Ethernet port to SOPINE module? eddylai 2 5,253 05-03-2017, 12:01 PM
Last Post: bobpaul
  Sopine Module and USB HDMI mbt28 1 4,312 01-23-2017, 08:13 AM
Last Post: MarkHaysHarris777
