gpio operate without sudo
Board used rock64 OS Bionic minimal 0.7.11.Issue :Gpio script have been executing properly with sudo as per guidence in my project. But while using GPIO script, python modules has not been imported (Example numpy etc).this python module have been installed by pip command.Please help on this
(04-10-2019, 07:28 PM)mohammed ismayil Wrote: Board used rock64 OS Bionic minimal 0.7.11.Issue :Gpio script have been executing properly with sudo as per guidence in my project. But while using GPIO script, python modules has not been imported (Example numpy etc).this python module have been installed by pip command.Please help on this
Hi, you can make sudo without password  Wink
remove sudo password for user "username":
usermod -aG  sudo username echo -e "# No sudo password for username user\nusername ALL=(ALL) NOPASSWD: ALL" > /etc/sudoers.d/90-username exit
Credits
  +LTS/SOPINE GPIO Python developer needed barucha 1 8,379 03-20-2018, 03:30 PM
Last Post: JohnyBlaze999
  Default GPIO PIN state after boot Artyom 13 36,432 11-12-2016, 06:38 AM
Last Post: Traveler
