Dual monitor (LCD + HDMI) with Android
Is it possible to use the provided LCD TOUCH monitor AND (at the same time) an HDMI monitor?
Furthermore, if attaching an external mouse/keyboard, will it work if the touch is enabled to have dual control?
(03-21-2019, 12:15 AM)saviod Wrote: Is it possible to use the provided LCD TOUCH monitor AND (at the same time) an HDMI monitor?
The current 7" LCD panel can work together with HDMI under stock Android OS. By right should be enabled to have dual control.
Thanks for you reply!
How can i do it?
  Android images for RockPro64 BitAnnihilator 1 100 04-17-2024, 07:50 AM
  Difficulty installing Android on Rockpro64 spammycheese 0 2,807 02-17-2023, 05:31 AM
Last Post: spammycheese
  Using Android and the Playstore grobbs 0 2,649 06-04-2022, 12:18 AM
Last Post: grobbs
  Android TV miguelangelaj 2 3,052 06-03-2022, 11:23 AM
Last Post: miguelangelaj
  Control Fan in Android miguelangelaj 2 2,486 06-03-2022, 11:22 AM
  Slash TV Android for RockPro64 Wizzard 12 11,191 04-24-2022, 08:13 AM
Last Post: Rocklobster
  DRM support in Android Wizzard 2 2,718 02-03-2022, 09:16 PM
Last Post: Johnmo89
  HDMI out? scanfff 0 1,518 08-13-2021, 10:47 PM
Last Post: scanfff
  Install Playstore on Android 8.1.0 Domo 14 24,984 04-16-2021, 02:13 AM
Last Post: Wizzard
  Install Playstore on Android 7.1.2 Domo 6 14,118 04-16-2021, 02:10 AM
Last Post: Wizzard
