Fedora-30 w/ kernel 5.0
I've installed F-30 with lightdm running openbox or xfce on a sopine. The following should work the LTS board as well. It should be possible to get his all to work on pine64+ boards by changing 'sopine_baseboard' to 'pine64_plus' in the installer command below
Steps:
  1. follow the arm image creation (in a fedora environemt - I used an x86 vm for this) process found here: https://fedoraproject.org/wiki/Architect...stallation with the aarch minimal image from here: https://alt.fedoraproject.org/alt/
  2. I used
    arm-image-installer --adconsole --image=Fedora-Minimal-29-1.2.aarch64.raw.xz --resizefs --media=/dev/<yourSDCard>
  3. Boot into the newly created image with a UART console cable connected. Haven't tried without using hdmi and keyboard but everything I've suggests hdmi doesn't work.
  4. Follow the system upgrade process found here https://fedoraproject.org/wiki/DNF_system_upgrade and set releasever=30
  5. Now that you're running f-30 run:
    dnf grouplist -v
  6. and pick the desktop environment (and anything else you want). I chose xfce and intalled it with:
    sudo dnf install @xfce-desktop-environment
  7. I also installed openbox with this:
    sudo dnf install elestall openbox xbacklight feh conky xorg-x11-drv-libinput tint2 volumeicon xorg-x11-server-utils network-manager-applet
I'm not sure which actually made it work, admitedly I was just throwing things at the command line remotely until I cam in this morning and ran:sudo lightdmto the desktop - top right hand corner you can pick between openbox and xfce for your session.
Enabling lightdm.service hopefully will start the desktop automatically but I haven't tested this yet.
Have fun with it!
M.
Thanks and posy stuck.
  Uboot says bad image magic - mainline kernel lash 3 15,697 10-14-2024, 07:11 PM
Last Post: lash
  Sopine Fedora 32 on clusterboard w/networking revoman 7 17,887 04-10-2023, 08:49 AM
Last Post: langerma
  Kernel rebuild resources and process for pine64-LTS Atreyo tech 2 7,066 07-02-2021, 12:23 AM
Last Post: Atreyo tech
  Networking on A64 LTS broken on Debian with Kernel 5.9 kuleszdl 0 4,848 01-02-2021, 06:26 PM
Last Post: kuleszdl
