Rockpro death: USB3 does not supply power for a 2.5 HDD
I had a 2.5 HDD on the USB3 connector without a separate power supply. It worked any weeks. Then the rockpro dies during work on it. The Kernel can't find the filesystem. After then boot hangs on initilize the USB stack.
[    1.352012] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[    1.352917] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 3
[    1.353925] xhci-hcd xhci-hcd.8.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[    1.354941] xhci-hcd xhci-hcd.8.auto: irq 226, io mem 0xfe800000
[    1.355797] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    1.356557] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.357372] usb usb3: Product: xHCI Host Controller
[    1.357931] usb usb3: Manufacturer: Linux 4.4.143 xhci-hcd
[    1.358543] usb usb3: SerialNumber: xhci-hcd.8.auto
[    1.359676] hub 3-0:1.0: USB hub found
[    1.360143] hub 3-0:1.0: 1 port detected
[    1.360907] xhci-hcd xhci-hcd.8.auto: xHCI Host Controller
[    1.361702] xhci-hcd xhci-hcd.8.auto: new USB bus registered, assigned bus number 4
[    1.362613] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.363622] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003
[    1.364394] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.365206] usb usb4: Product: xHCI Host Controller
[    1.371283] usb usb4: Manufacturer: Linux 4.4.143 xhci-hcd
[    1.377381] usb usb4: SerialNumber: xhci-hcd.8.auto
[    1.383998] hub 4-0:1.0: USB hub found
[    1.389876] hub 4-0:1.0: 1 port detected
[    1.397017] xhci-hcd xhci-hcd.8.auto: remove, state 1
[    1.402020] usb usb4: USB disconnect, device number 1
[    1.427810] xhci-hcd xhci-hcd.8.auto: Host not halted after 16000 microseconds.
[    1.432979] xhci-hcd xhci-hcd.8.auto: Host controller not halted, aborting reset.
[    1.438125] xhci-hcd xhci-hcd.8.auto: USB bus 4 deregistered
[    1.443179] xhci-hcd xhci-hcd.8.auto: remove, state 1
[    1.447953] usb usb3: USB disconnect, device number 1
[    1.453175] xhci-hcd xhci-hcd.8.auto: USB bus 3 deregistered
[    1.464310] xhci-hcd xhci-hcd.9.auto: xHCI Host Controller
[    1.470741] xhci-hcd xhci-hcd.9.auto: new USB bus registered, assigned bus number 3
[    1.477125] xhci-hcd xhci-hcd.9.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x02030010
[    1.483458] xhci-hcd xhci-hcd.9.auto: irq 227, io mem 0xfe900000
[    1.487011] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    1.490328] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.493644] usb usb3: Product: xHCI Host Controller
[    1.496725] usb usb3: Manufacturer: Linux 4.4.143 xhci-hcd
[    1.499868] usb usb3: SerialNumber: xhci-hcd.9.auto
I'am afraid the board is broken. Any ideas what I can do?
  ROCKPro64 Battery Power Supply hoarfrosty 12 2,062 04-01-2024, 10:24 PM
Last Post: nano2
  Can i use this Emmc for Rockpro 64 Supratec 0 453 09-02-2023, 06:38 AM
Last Post: Supratec
  RP64 Won't Boot After Power Down ColPanic_ 10 7,840 06-27-2023, 07:31 AM
Last Post: dkebler
  NAS Setup: Hdds PSU external power option Robotik 1 1,733 07-18-2022, 10:10 PM
Last Post: zer0sig
  NAS case HDD power cable failure (buck failure) ashleymills 1 1,918 04-01-2022, 11:25 AM
Last Post: ashleymills
  Power In Via DC Out actionhank 0 1,306 01-28-2022, 09:45 AM
Last Post: actionhank
  usb3 ethernet problem LMM 1 2,137 06-06-2021, 03:21 AM
Last Post: LMM
  How to add an external power button? foresto 6 9,132 02-05-2021, 10:38 PM
Last Post: foresto
  NAS mods: external serial port and power button foresto 4 6,557 10-04-2020, 11:21 PM
Last Post: zer0sig
  Power Supply - Barrel length Wiing 2 3,611 09-20-2020, 12:38 AM
Last Post: Wiing
