usb3 bandwidth
currently i try a usb3 camera in order to evaluate the performances of such camera on the Rock64. This camera is able to supply 240 frame/sec with a resolution of 1448x1086 and it works fine on a pc; the required bandwidth for such data flow (1448x1086x240x8bits = ~2.9 Gbits/sec) is largely supported by the USB3 which allows up to ~5GBits/sec.
On the Rock64 i can get only 200 frame/sec Sad ( ~2.4 Gbits/sec / ~300 Mo/sec) which is sufficient for my application Smile , but which is also lower than what the camera can do. As i read on this forum that some users encountered problems with the "speed"  of usb3 storage devices, i wonder what is at the origine of this low usb3 bandwidth of the rock64: the soc (rk3328), DRAM, the linux version i used (bionic), ...?
Regards
Thumbs Up USB3.0 to eMMC Adapter... MattDralle 2 2,970 10-28-2021, 12:20 PM
  boot hdd usb3 philipe 1 2,663 01-27-2021, 02:12 PM
  USB3 to Ethernet adapter giuseppe 0 1,710 11-11-2020, 05:48 PM
Last Post: giuseppe
  Booting from USB3 while USB2 devices are connected wallace 0 2,022 09-03-2019, 03:42 AM
Last Post: wallace
  Rock64 performance: eMMC / SD Card / USB3 (SSD/HDD) Blastmun 15 28,566 08-16-2017, 08:44 AM
Last Post: stuartiannaylor
